Old 12-20-2008, 05:57 PM   #1
packrat42
packrat42's Avatar
Has anyone ever made a Homemade Flip Kit?
First off Merry Christmas. My question is has anyone ever made a flip kit for a 67-72 with rear leaf springs? If so what all is involved?
packrat42 is offline   Reply With Quote
Old 12-20-2008, 09:54 PM   #2
Wild83C10
Wild83C10's Avatar
Re: Has anyone ever made a Homemade Flip Kit?
The best and cheapest way is to cut off the old perches and weld new ones on. Then all you need to buy are new perches.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 12-21-2008, 05:46 PM   #3
ENHANCED AIR RIDE
Agreed!!!
ENHANCED AIR RIDE is offline   Reply With Quote
Old 12-21-2008, 09:37 PM   #4
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Won't that put the rear end to far back??? On my bell tech flip kit, it has a hole in the flip saddle that has to be towards the front of the truck. Just wondering???
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 12-21-2008, 11:36 PM   #5
ENHANCED AIR RIDE
The offset hole is to correct pinion angle. Set ur PA and weld on.
Old 12-22-2008, 12:13 AM   #6
joe231
joe231's Avatar
my under standing is the off-set hole is to move the diff back. when you flip the axle to the top of the springs it moves it closer to the transmission, so to keep the slip joint from bottoming out during suspension travel, the diff is moved back 3/4" IIRC
to correct pinion angle, the u is uneven, or with the better kits, it is adjustable
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-22-2008, 09:17 AM   #7
SCOTI
SCOTI's Avatar
x2. The brackets not only correct pinion angle, they reset the wheel base as it changes when lowered that much.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-22-2008, 12:40 AM   #8
nuke1
nuke1's Avatar
i just did that to the 58 apache we are doing, they are right, center you axle side to sid, set your pinion angle and weld the perches on, easy.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 12-22-2008, 03:40 AM   #9
Musclerodz
I made a set for my blazer as well as zero rate to relocate the axle. Not difficult if you have access to the proper tools. They are not that expensive to buy either.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 12-23-2008, 10:14 PM   #10
joe231
joe231's Avatar
Hey Mike,
can you elaborate on the "zero-rate"
what is it, what does it do, and how did you make it?
CHEVY ONLY
Old 12-22-2008, 09:45 AM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Remember that axle saddles are available at any trailer store, Northern Tool, or Tractor Supply MUCH cheaper than mail order specialty places too.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-22-2008, 11:19 AM   #12
packrat42
packrat42's Avatar
Thanks guys.
