Old 12-22-2008, 02:27 PM   #1
bmfpeterson
bmfpeterson's Avatar
What is the biggest tire size I can run 71 sb
I have a 71 short bed I'm building. I have the block almost done with a tranny and am working on the rear suspension now. I want to keep the 12 bolt rear end and leave the frame in tact. I plan on running tubs in the bed to fit the biggest (widest) tire that I can. Does anyone know how big i can plan on with that all said?
Any help would be greatly appropriated!!!!!
bmfpeterson is offline   Reply With Quote
Old 12-22-2008, 02:30 PM   #2
LuckyHenriksen
LuckyHenriksen's Avatar
Re: What is the biggest tire size I can run 71 sb
I hear the 12 inch wide wheels with 7.5 inch backspace will clear no probem. Im guessing up to a 325 or bigger will fit
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-22-2008, 04:47 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
Every truck can be slightly different so it's always better to mock up first. If you have the stock 71 rear, it's a little wider than a 67-70 rear so you won't fit the widest rim or tire possible. There's lots of variables including how much you're willing to trim off the bedsides where the inner parts hang down below the tubs.
Old 12-22-2008, 06:34 PM   #4
bmfpeterson
thank you for the help!
I have no problem taking whatever i need out of the bed sides. I have a plasma and a cut off wheel!!! haha. I am going to mock up maybe this weekend, I just want the biggest footprint that will work without having to back half and tub the rear end. I am going to run a four link kit so the springs and trail arms will be out of the way. just a matter of measuring, I was hoping to get on here and have someone tell me the magic number but I probably wouldnt have listened to it anyway.haha
Thanks for all the help if any more input please let me know.
Old 12-22-2008, 11:23 PM   #5
SCOTI
SCOTI's Avatar
With the trailing arm/coil suspension, you can run 14" wide wheels w/9-9.5"bs & 31x18.50 tires. The only mods required are custom back-spaced wheels & removing the rear bumpstop + bracket from the framerail.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-22-2008, 11:59 PM   #6
ratrod67
ratrod67's Avatar
I'd like to see pics of that.
ratrod67 is offline   Reply With Quote
Old 12-23-2008, 12:29 AM   #7
SCOTI
SCOTI's Avatar
I only have pics from wayyyy back in the day. When I tried to scan them, the underside of the truck was too dark to get a clear idea on the proportions of everything.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-22-2008, 04:54 PM   #8
Ackattack
Ackattack's Avatar
I'VE GOT 315/35/20 on mine and have a lot of room for more with mine tubbed. My tires are pushed out as far as possible
Ackattack is offline   Reply With Quote
