Old 12-22-2008, 05:48 PM   #1
AH619
AH619's Avatar
Drop springs is 3-5 ok without c notch?
Thinking about lowering my first truck. It a 68 swb that we are building for my 15 year old. Had seen the drop springs and noticed they come 1/3 or 3/5. We are using 15 inch aluminum wheels with 60s front and 50s rear. I cant go to the expense of drop spindles and c notches. Whats my best bet?
72 2wd lwb cheyenne super youngest son.green/white
72 2wd lwb cheyenne super oldest son.green/white
71 4wd 3/4 cheyenne super frame off manderin
copper / white 4 inch lift. FINALLY DONE / SOLD
72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO
REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR
COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856
AH619 is offline   Reply With Quote
Old 12-22-2008, 05:55 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Drop springs is 3-5 ok without c notch?
You can run 6 inch rear springs without a notch. I've done it many times.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-22-2008, 05:55 PM   #3
67_C-30
I have a radical idea!
67_C-30's Avatar
I lot of people on the board are running 2 1/2" spindles and 1" lowering springs and 6" drop springs in the rear without a C notch. I have my beater truck dropped 3/5" with just springs and it does fine, but they are little harder to align than the drop springs. I have heard of a few people saying that some of the 3" drop springs pop out of the spring pocket when you jack them up.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 12-22-2008, 06:14 PM   #4
AH619
AH619's Avatar
Originally Posted by 67_c-30 View Post
i lot of people on the board are running 2 1/2" spindles and 1" lowering springs and 6" drop springs in the rear without a c notch. I have my beater truck dropped 3/5" with just springs and it does fine, but they are little harder to align than the drop springs. I have heard of a few people saying that some of the 3" drop springs pop out of the spring pocket when you jack them up.
did you mean harder to alighn than with drop spindles?
Old 12-22-2008, 06:09 PM   #5
LuckyHenriksen
LuckyHenriksen's Avatar
Yep my 3 inch front drops would almost fall out if there wasnt any pressure holding them down
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-22-2008, 06:22 PM   #6
Shane
Shane's Avatar
You won't need a notch, but an adjustable trac bar (panhard bar) is a good idea. It helps to re-center the axle.
Shane is offline   Reply With Quote
Old 12-22-2008, 06:31 PM   #7
AH619
AH619's Avatar
So 3/5 springs would be ok by themselfs? And not be too much of a pain? Would it set about level?
Old 12-22-2008, 06:41 PM   #8
67_C-30
67_C-30's Avatar
Yes, it is a little more involved when aligning it due to changing front a geometry, but it is doable. The 3/5 drop sits pretty level and looks good.
Here's my beater dropped 3/5".
My trucks
Old 12-22-2008, 06:46 PM   #9
AH619
AH619's Avatar
yes, it is a little more involved when aligning it due to changing front a geometry, but it is doable. The 3/5 drop sits pretty level and looks good.
thanx
Old 12-22-2008, 07:26 PM   #10
Puropedo
Dont need a notch for a 5-6" rear drop (like everybody is telling u) Here's my
72 cheyenne with a 5" rear (there's still about 3.5 inches of travel between the differential and frame.
Puropedo is offline   Reply With Quote
Old 12-23-2008, 02:45 AM   #11
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
What brand of rear springs are those? I bought a set of mcgaughy 5" rear spring and it lowered it like 6" to much for me. My 4" springs are just not enough. Looking for a true 5" spring. Also what are you doing for drive line angle?
68 C-10 KID is offline   Reply With Quote
Old 12-22-2008, 09:10 PM   #12
primered_junk
ASE master tech/machinist
primered_junk's Avatar
Heres my old 71 GMC, 3/5, 235/70/15 and the rears were the equivalent to a 31/10.50. The 66 parked behind it had the same drop with custom made torque thrusts, 17x6 front, and 17x12 rears.
"I sit here and I pray in my broken down Chevrolet....."
primered_junk is offline   Reply With Quote
Old 12-23-2008, 01:04 AM   #13
MellowYellow70
My 70 is dropped 5" in the front with springs and modified a-arms. The rear is dropped 6.5" with springs and blocks on the trailing arms. Rode great and never had a problem with 275/60/15 all around. Going with 17's and a 5.3 swap currently.
If patience is truely a virtue, Then I am so screwed
1970 Chevy SWB 331 sbc and all the goodies. Under resurection
2001 Vette
MellowYellow70 is offline   Reply With Quote
Old 12-23-2008, 01:33 AM   #14
nicolas72gmc
nicolas72gmc's Avatar
Do you have any more pics of the 71 with that drop? Thanks man.
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 12-23-2008, 10:05 AM   #15
69halfton
69halfton's Avatar
you guys are saying 3/5 drop with only coils? im looking at the early classic website, they only offer up to a 2 inch drop with coils in the front.
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 12-23-2008, 11:05 AM   #16
chevy_mike
Never Ending Projects
chevy_mike's Avatar
That's because I think ECE doesn't recommend 3" drop coils in the front. It's hit and miss if you can get the alignment set correctly and since ECE is wanting to give the very best, they recommend dropped spindles and coils for 3"+ drops.
As they say, just because you can... doesn't mean you should. YMMV.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-23-2008, 10:17 PM   #17
72BlckButy
Tot Roddin'
72BlckButy's Avatar
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-23-2008, 12:59 PM   #18
kcjones
I wish I was a cowboy
kcjones's Avatar
I can't agree on the 6" drop with no cnotch. I agree that you can run a 6" drop spring and still drive the truck, but you'll have like 1/2" clearance between the frame and axle tube.
I have 5" drop springs and 1" blocks, and if I didn't have the notch, I'd have the frame on the axle every single bump I hit. I know it's doable, but you can't really ever expect to haul anything (not even your old springs) anywhere without hearing and feeling that obnoxious bump in the back.
This is only my experience, I have heard of lots of people running 6" drops without issue, it just hasn't been my experience.
5" drop in the back shouldn't be a problem even with a light load in the bed. ECE is great, PerfOnline is good (in my experience again), and CPP is not-so-good, mostly because of communication and customer service.
Oh, yeah, one more comment: definitely run drop spindles, don't do the 3" drop spring in front. Crappy ride, weird alignment, and weird characteristics around corners - you know the thing where even right after a good alignment, so still get squel around corners, only to the right? Yeah, weird stuff man, get the drop spindles.
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 12-23-2008, 01:44 PM   #19
AH619
AH619's Avatar
O k thanx guys. I knew yall would steer me straight. Thanx again
Old 12-23-2008, 03:06 PM   #20
LuckyHenriksen
Can you run a 6 inch spring AND a set of 2 inch blocks?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-23-2008, 04:47 PM   #21
kcjones
kcjones's Avatar
You sure can, but you'll definitely need the notch, then. Here's a quick cell pic of why a 6" drop spring probably should have a notch:
Also, in the pic below, with this stuff in the bed, I was drooping below the frame/axle clearance height, so with a 6" drop spring and any load, you'd be hitting frame:
-Kris
Old 12-23-2008, 08:22 PM   #22
Tx Firefighter
Attachment 414619
Attachment 414620
I cannot dispute your pictures, but I do have some thoughts.
Your truck was originally a 3/4 ton longbed. Longbed, reinforced frame, tool box in bed,...
My experience has been with 1/2 ton shortbeds and Early Classic Springs and never a c notch.
As a matter of fact, I currently have a Honda Goldwing in the bed of my 1/2 ton shortbed truck and I have driven it no sweat.
Old 12-23-2008, 09:07 PM   #23
see ten
WTB this ad
see ten's Avatar
I have Early Classic 6" drop springs and it does bottom out from time to time. TX I know you say you have never had a problem with them and your statements had a lot to do with my use of ECE 6" drop springs. That being said I don't doubt you or your statements...but my truck does bottom out from time to time out back. I drive my truck a lot and I drive it hard and it doesn't have issues all the time but it does have issues. So, from my experience, and my opinion, 5" of drop is optimal if you want to ride without bottoming out....Do I want to change my springs out now that I've gotten used to the look and the ride? Hell no!
see ten is offline   Reply With Quote
Old 12-23-2008, 09:19 PM   #24
see ten
WTB this ad
see ten's Avatar
My 3.5"/6" drop all ECE.
Brian's 2.5"/5" drop all ECE same tire wheel sizes.
2.5" drop spindles will make you much happier than 3" drop springs in the long run. If you can't afford em...save your money til you can. If I can't change your mind at least buy a set of 3" drop springs from me so I can save you some money. I've got a set we took out of one of my buds trucks when he went to drop spindles. You can get an alignment with 3" drop front springs but your ball joints will be at less than their optimal angle. Not to mention your lower control arms will more than likely bottom out on the crossmember.
Old 12-24-2008, 04:37 PM   #25
au03z71
au03z71's Avatar
Did you notch the frame?
au03z71 is offline   Reply With Quote
