![]() Join Date: Dec 2008
A/c Controls delete
I am running a Mojave heater and don't want a big open hole in my dash any body got any ideas, pics please!
Retired Air Force Veteran
![]() Join Date: Aug 2007
Re: A/c Controls delete
Check out Board Member: Mekdad
He has 3 posts with Custom Aluminum Pieces, Maybe he can make that Heater Control Delete for you (Below are links to his posts) Good Luck http://67-72chevytrucks.com/vboard/s...d.php?t=320284 http://67-72chevytrucks.com/vboard/s...d.php?t=316255 http://67-72chevytrucks.com/vboard/s...d.php?t=316394
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 12-23-2008 at 12:18 AM. |
![]() Join Date: Oct 2005
I have pulled out all my radios and heaters in my trucks..Radio deletes work great in the heater space.Sorry no pics all my trucks are in storage for winter..mekdad made me a radio delete plate that would work to..JZ
WTB 1972 CHEVY 3/4 4X4 1971 chevy c30 4x4 NAPCO (project) 1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers 1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete 2006 chevy LBZ crew cab duramax,4 inch,beadlocks 2015 chevy tahoe Z71 my fifth one,love em 2016 chevy 2500HD Z71 LTZ duramax midnite 2018 chevy suburban Z71 midnite |
Old Skool Club
![]() Join Date: Jun 2001
1. Get a piece of 20-ga. sheet metal.
2. Make a template of the hole. 3. Transfer the image to the sheet metal with a no. 2 pencil. 4. Cut it out with a pair of metal shears/plasma cutter. Trim to fit. 5. Carefully weld it in. Grind down the welds, as needed. 6. Finish it, using a minimum amount of body filler. This is the method that a friend would take in filling in a hole or creating a part. He's good.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
