12-26-2008, 07:28 PM | #1 |
need help
im having trouble getting my truck to turn over.ive checked all the electrical parts plugs are sparking but im getting no fire.sometimes it will upchuck through the carb.what am i doing wrong.thanks for your help.btw the motor is a olds 350
12-26-2008, 08:29 PM | #2 |
The Older Generation
Re: need help
Sounds to me like your timing is off for some reason... Or the spark plug wires are installed wrong. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-26-2008 at 08:30 PM. |
12-26-2008, 09:54 PM | #3 | |
Active Member
Re: need help
Was it running before and all of a sudden doesn't run? When you say plugs are "sparking but no fire" do you mean you're getting spark when you crank it but the engine is not starting? Like Lockdoc says timing could have jumped (worn timing chain) or plug wires not installed right. |
12-26-2008, 11:30 PM | #4 | |
Re: need help
12-28-2008, 01:54 AM | #5 |
Re: need help
it now runs after not running for well over a year.i rechecked for tdc,rewired the distribitor,andf added fresh gas and octane booster,it turned over an ran like a champ.i thank all for there help
12-28-2008, 11:01 AM | #6 | |
Re: need help
Glad you got it sorted out. Now you can go for a ride... LockDoc
