12-29-2008, 04:54 PM | #1 |
Baby it's cold outside
Any help would be greatly apprecated
2002 Blazer 4.3 Flushed radiator today Engine temp is normal,not overheating Have no heat or defrost Fan blowes cold air If I had hair I would pull it
02 Blazer 66 lwb step 66 lwb feet :flagw Working to live not living to work RIP RS |
12-29-2008, 08:39 PM | #2 |
Re: Baby it's cold outside
Flush the heater core. Probably more than once, its a known issue with S10s.
01-03-2009, 08:28 AM | #3 |
blood type; Retumbo
12-29-2008, 09:14 PM | #4 |
BAD BOW-Silverado XST
Back flush the core. Remove the lines from the system. Use a water hose to flush it really good.
Does it blow air? Check the vacuum line under the hood. The line connects to the vacuum ball. |
01-04-2009, 06:15 PM | #5 |
Thanks all for the input
I flushed for 2 days and it did not help Installed a new heater core and now have heat 10 hr to install.Can't beleive they made it so hard to get at Thanks again for yalls help
01-04-2009, 09:40 PM | #6 | |
Trucks N Tranzams
Thats rough. I think I will make flushing mine a regular thing.
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
01-04-2009, 10:41 PM | #7 |
01-05-2009, 03:57 AM | #8 |
I converted mine to yellow stuff.
01-05-2009, 06:54 AM | #9 |
blood type; Retumbo
dontcha just love dexcool?
I hope you didnt put a long screw in the hole behind the blower resistor. if so you will be stuck on hot and possibly ruin a door actuator. |
01-09-2009, 12:11 AM | #10 |
That sounds like the voice of experience...
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
