12-30-2008, 10:03 PM | #1 |
Power Steering Pump Bracket
Need some advice. Got a 400 SB (GM3951511) in my 66 Chevy LWB. Added a power steering box and CPP support bracket. Got that all mounted. The problem is not being able to find a power steering pump bracket that will mount to the small block. Any recommendations on the year and model I might search for? Seems that the yards I checked here in Dallas don't have many (if any) older blocks, finding mostly serpentine setups.
Thanks in advance. |
12-30-2008, 10:05 PM | #2 |
Re: Power Steering Pump Bracket
... long or short water pump?
12-30-2008, 10:18 PM | #3 |
Long
12-30-2008, 10:25 PM | #4 |
I have everything you'll need, from a 77 w/400. I'll get pics tomorrow.
01-01-2009, 01:38 AM | #5 |
Pictures would be great. Thanks for the reply..
01-02-2009, 04:54 PM | #6 |
You'll need to use the correct long water pump style pulleys as well. Is the p/s mounting boss on your water pump threaded or smooth hole through? There are two different mounts. I should have both, this one is for a threaed boss.
Cheesy cell phone pic, sorry. =========================== Last edited by Cyclone; 01-05-2009 at 08:30 PM. |
01-02-2009, 08:44 PM | #7 |
If you are interested in an aftermarket solution, I used this bracket from March Performance on my 63. Fit perfect, easy to adjust, with great belt alignment. It all mounts to the two water pump bolts on the driver's side. It is a little pricey; although they do sell a gray powercoated version for less. Here's a link:
http://store.summitracing.com/partde...5&autoview=sku Rick
RED RUMBLE 1963 C10 Chevy Truck Owned since 1984 |
01-05-2009, 07:45 PM | #8 |
Did you have any issues with the March brackets in a case where you did not use any of their other brackets, I had read where some folks had difficulty there?
01-05-2009, 07:44 PM | #9 |
it is smooth hole through.
Thanks, BTW, I don't see the pictures anymore. |
01-09-2009, 11:21 AM | #10 |
01-05-2009, 08:31 PM | #11 |
fixed, sorry bout that
01-08-2009, 03:36 PM | #12 |
Cyclone thanks for the pics.
01-08-2009, 07:05 PM | #13 |
I am only using the March Power Steering Pump bracket. I had no problems with other accessories. Even the hose connection were fine. My engine is a 1969 350c.i. from an Impala.
Rick
