![]() Join Date: Oct 2008
"La Veija"
Quick summary:
1968 C10, 454 BB I bought my truck around late Sept 2008. I bought an addtional frame to start the bag work. Then I started replacing part: Conversion kits, cab corners, shaving fenders and so. Took about 3/4 of an inch bondo from roof and rear middle cab. Then Decided to buy an original, no body work done cab. Puchased a Dropmember.... So here it goes. Last edited by C10Sim; 01-02-2009 at 01:32 AM. |
Re: Project "Dirty D"
Started to shave fenders and gas hole
Replaced the cab corner, which it went pretty smooth.
I discovered that my grill had a thick layer of bondo, so I cut the center stip that was bent and replaced with another.
Well I purchased this frame for $100 at a swap meet and water blasted it. It is only temporally, once frame gets bagged, it will be sent out for power coat.
Installed a 6 lug conversion kit. I purchased a Dropmember from Nate. ![]() This means all new springs, spindles, ball joints were pointless Last edited by C10Sim; 01-02-2009 at 01:47 AM. |
Well on New Years of 2009 I installed my dropmember, and 2 weeks before that I purchased a another cab because my truck cab had bad deep dents that had been badly work and it had to much streched metal. I decidedto buy a cab that had original paint job, that way I knew exactly what I was getting into. The good thing is that the cab corners dont need replacement but the rockers do (It ok because I was going to replace them on the other truck aswell). The floor need replacement but only a small place on driver side. Roof is in excellent condition
![]() I am not done cutting the frame for the rack and pinion. I wanted to confirm it with Nate before anyrhing. I will try to keep posting. |
I dont know the name but i purchased them at "Harbor Freight Tool". This tool is really helpful when you are installing aftermarket panels.
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
Here's an update:
-mounted front tires -installed steering joints -installed sway bar I didnt place the spacer in the right location for the rack and pinion which bent when I lowered it, but wacked back to place and made the proper installation.
Nice progress
Resident of Here
Lookin good! Keep up the good work! What kind of welder do you use?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() Last edited by thirdstreettito; 01-02-2009 at 11:07 AM. |
Its a Millermatic 130 XP. It works great but I am starting lean over the lincoln 135-140 it sound beatiful compared to my Miller (Maybe its just my machine). I will be getting a Lincoln today.
kool
nickle and dime |
Well I finally cut the frame to get clearence for therack and pinion.
#15 |
Since I had the welder out, I went ahead and shaved the gas hole.
Phillip13 Donated the gas delete panel, Thank You! ![]()
#16 |
man thats looking good
#17 |
Resident of Here
Lookin good! Keep it up!
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#18 |
THE DAMN YANKEE
Very nice, you do good work! Is that a DAMN YANKEE cab fuel tank delete panel?? LOL Phipp
#19 |
Looking good Im watching this one....gotta love those stepsides lol.
#20 |
Here goes an update March 29, 2009!
Well my business has increased, so my time is short now. I decided to get a cab that needed less work. I bought a cab off a board member and it was in real good condition. It only needs inner and outer rockers and cab corners plus my little extra areas that I want to shave ![]() I fab'd in new inners and coated them with por-15. Then I installed the new outer rockers. I also bought a new raditor support, It's not as tough as the orginial but cost effective due to the work my orginial needed.
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 Last edited by C10Sim; 03-29-2009 at 11:40 PM. |
#21 |
Went ahead and replced tthe passengers cab corner and coat the inside with por-15 aswell.
#22 |
I really didnt want to shave the drip rails on this cab because they were in perfect condition but that's a different project.
#23 |
VA72C10
![]() Join Date: Mar 2008
Looking good...that's going to be a sweet ride when done..Dropmembered with a BB
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#24 |
Thats looking pretty good
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#25 |
Alright here goes an update...
I bought a wiring hardness, lots of motor parts, weld in notch from Porterbuilt. My 454 is in the machine shop and is getting bored .030 over and getting all machine work done to heads aswell. They are going to install a thumper cam ![]() I have additional parts that I just order and should be here by next week.
