Old 01-03-2009, 12:31 AM   #1
Pont406
72 drag link and tie rods question
I am converting 69 c10 to a disc brakes from 72 c10. What is a difference between inner and outer tie rods? The way I see is that a mounting holes on the spindle and draglink are different size. Are the lenght the same or not? Can someone please post a pic of 71 or 72 c10 drag link and tie rods. I dont want to take front end a part untill I get all the parts. Thanks
Pont406 is offline   Reply With Quote
Old 01-03-2009, 08:30 AM   #2
70GMCer
70GMCer's Avatar
Re: 72 drag link and tie rods question
1st thing to do, is to take a picture of the setup you have now. That drag link can be installed backwards & you not know it until you go to make turns. You will have to change the outer tie rods to fit the 71/72 spindles, as they are bigger than the 67/70 ones. Look in the FAQ on here. These are many, many write ups on this conversion giving info that you will need.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-05-2009, 01:38 AM   #3
Pont406
Yes, I did a search on this. Here is my problem. All parts are for 71-72. I have 2 sets of outer tie rods but the inners wont fit. One set is too loose and the other too long. I just ordered a new set of tie rods for 72. Hopefully it will fix it.
Old 01-05-2009, 11:18 AM   #4
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
The earlier model drag link (67-70) and the 71/72 drag link are very similar in looks except the tapered hole for the inner tie rods is different between the earlier years a (67-70) opposed to the 71-72. The hole for the pitman arms are the same for 67-72. Your best bet (I just completed this conversion on my 69') is to get new inner/outer tie rods and sleeves for the 71-72 and get a 71-72 drag link. (Board Member: thelonerife, a.k.a. Chuck should still have one for sale)
This way, all your parts will work properly with the 71-72 spindles.
New Parts (inners/outers/sleeves) at Advanced Auto were about $80.00. Well worth the dough. I went with the Moog Parts.
Remember, the Master Cylinder/proportional Valve and Front brake lines require changing. With all of the change over and new parts, the ole' 69' drives like a champ.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 01-06-2009, 08:46 PM   #5
chevysittinsidewayz
the 71/72 tie rods use a bigger tapered end and the threaded end is 11/16 rather than 5/8 on the 67-70. i used 67 inners and outers and ran some sleeves from speedway motors and built some bushings to fit the smaller tapered end of the tir rods in the later spindles.
chevysittinsidewayz is offline   Reply With Quote
