Old 01-03-2009, 02:59 PM   #1
lumpyguy
horn wiring
I have a 1969 GMC 1/2 ton base model no power anyhting and 6 cyl 3 on the tree I got the truck part done but I have a horn in the box of parts but I cant seem to find where I goes what colour is the wire for it and where is it located I cant seem to find anything in my Hayes manual any help or pictures would be great thanks
lumpyguy is offline   Reply With Quote
Old 01-03-2009, 03:11 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: horn wiring
Horn wire is green, as I remember. There should be a relay that you will hear emit a clicking sound, with no horn connected. If you hear that sound, then you should be able to have an operable horn when it is connected....unless there is a break in the wire between the relay and its terminus.
Member Nr. 2770
Old 01-03-2009, 03:42 PM   #3
DB Smith
Old Shovel Rider
DB Smith's Avatar
Re: horn wiring
You mean where the horn mounts?? On the core support to the outboard side of the radiator. It's on the drivers' side near the regulator. You should see that green wire with a coupler on it coming from the harmess near the horn location.
Daryl....
'68 C/10 Stepside 2007 Build Page
DS Originals
Old Bikers.US
DB Smith is offline   Reply With Quote
Old 01-03-2009, 03:45 PM   #4
clean cut creations
Re: horn wiring
Originally Posted by db smith View Post
you mean where the horn mounts?? On the core support to the outboard side of the radiator. It's on the drivers' side near the regulator. You should see that green wire with a coupler on it coming from the harmess near the horn location.
x2
Don't tell me what you're gonna do...SHOW me what you've DONE!!!
Click here for the TRUTH...
clean cut creations is offline   Reply With Quote
Old 01-03-2009, 04:13 PM   #5
cdowns
cdowns's Avatar
Re: horn wiring
take sandpaper and clean to shiney metal where the horn mounts to the core support because thats how the horn is grounded// doesnt hurt to shoot a bit of wd40 into the horn opening to lubricate the diaphram either
