Old 01-03-2009, 05:32 PM   #1
apachedaddy
apachedaddy's Avatar
Question trailing arm question???
My drivers side trailing arm has some seperation in the halfs.. Can i take a couple of the rivets out clean it up clamp it back together and weld... or should i try and find a replacement for this???? thank you for your time...
apachedaddy is offline   Reply With Quote
Old 01-03-2009, 06:50 PM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: trailing arm question???
You sure can....that would be even stronger than OG.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-04-2009, 09:47 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
I would weld them up even if they weren't separating. I've used the weld-in reinforcement plates (weld to the top and bottom of the arms) that a few vendors sell in the past on a set of trailing arms with excellent results. Good luck.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-04-2009, 02:47 PM   #4
joe231
joe231's Avatar
i question the need for more rigidity...i believe the original arms were designed to have some flex....but anyway
yes you can weld them up
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-04-2009, 02:55 PM   #5
55Series2
One thing to remember is that they are not riveted together; they are plug welded. The best way to separate them is cut the welds with a sawzall. You will most likely have dirt and debris trapped in there also. After you split them and clean them, weld them back together.
John
Albuquerque, NM
'55 2nd Series 3100
'57 Ford RanchWagon
07 H-D Electraglide UltraClassic
55Series2 is offline   Reply With Quote
