Old 01-04-2009, 03:13 PM   #1
idonutn0
Doing away with vents in the cab???
I was wanting to smooth the cowl, fix the rust and weld up the vent holes inside of the cab.
Has anyone done this? Are there any reasons why I shouldnt do it?
idonutn0 is offline   Reply With Quote
Old 01-04-2009, 03:33 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Doing away with vents in the cab???
If you have factory A/C, the passenger side vent is for recirculating air, and you need that one
Old 01-04-2009, 03:34 PM   #3
idonutn0
I was planning on running an aftermarket AC system in it.
Old 01-04-2009, 03:39 PM   #4
mr48chev
mr48chev's Avatar
Depending on which unit you get some still require outside air or at lest it is desirable.
I've seen a few trucks with the panel filled but they were primarily show only trucks and didn't see a lot of if any real street use.
Old 01-04-2009, 04:32 PM   #5
heavy71chevy
heavy71chevy's Avatar
Ive thought about it myself...prolly gonna make covers to go over the holes out of leather..like to see pics if you do it
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 01-04-2009, 04:37 PM   #6
cdowns
cdowns's Avatar
the tighter you make the cab the greater chance of the windows blowing out in hot weather or the cab being vaccume sealed in cold weather
Old 01-04-2009, 06:46 PM   #7
Looking for a reason to "not" want vents(short for ventilation).
Old 01-04-2009, 07:21 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
Close it up if you want, use door vents (like the later model GM trucks) for control of air pressure in the cab. If you need some fresh air in there during your A/C ops, then make a smaller tubed vent connection, but the big dust holes can be closed.
Old 01-04-2009, 10:35 PM   #9
Mondo
Mondo's Avatar
I have Vintage Air, smooth cowl, blocked vent holes, well insulated etc... The only issue I have is that in the winter I have to run the heat with the A/C on to dehumidify or the truck steams up. The air gets warm but not hot (the A/C works awesome in the summertime).
No tint and there's not many places hotter than Bakersfield.. haven't had an air pressure problem. These trucks just ain't that tight.
Mondo is offline   Reply With Quote
Old 01-04-2009, 10:55 PM   #10
Chevymann1968
Chevymann1968's Avatar
Your truck looks really good !!!1 What color red is that!!!
1968 GMC
Rebuilding Stage
2001 Camaro SS SOLD
Chevymann1968 is offline   Reply With Quote
Old 01-04-2009, 10:24 PM   #11
BP68
BP68's Avatar
Check my build thread for a pic of my shaved cowl in primer.
I shaved the center of the dash, but kept the stock vent holes to the left and right. I plan to go with a dual billet center vent.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 01-04-2009, 11:47 PM   #12
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
i got my vents welded shut, and a smooth cowl...but i aint driving mine yet, check sig for pics, if there aint none i'll get some up asaic
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 01-05-2009, 06:15 PM   #13
Mondo
Mondo's Avatar
thanks,
It's GMs "bright red".
My cowl is fiberglass and I got it from Tony Gonzalez ( mgtp001@gmail.com )
Great fit and a lot less hassle... throw some paint on it and bolt it down
