For all who want to do a LSX trans plant.
Check this out! http://www.hotrodlane.cc/PDFFILES/85...s2%20truck.pdf
My Truck's not leaking its marking its territory! |
truck addict
Re: For all who want to do a LSX trans plant.
well that makes things a hole lot easier for us guys lookin to do that swap... now if it only had a price sheet to go with it...
#3 | |
Trucker.
truck addict
well i plan on doing it so i would like to know how much dough to save up for in the next decade...lol
They also have a LS1 swap in a yellow 77 C10. Look in their swap page. It was the first swap they advertised.
my swap is in the 5k + range already.
S&P have some good stuff, but they are on the more expensive side. I got my headers from them and a few fittings to tie up some loose ends. I have all the reciepts but im scared to add them up to see how much ive spent. Last edited by Cherub; 01-08-2009 at 05:39 PM. |
Ephesians 2:8
you "could" do it that way.
![]() That sure is a clean install!
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build Last edited by bowtieguy79; 01-08-2009 at 05:46 PM. |
Nice write up only thing i didn't like was the pedal i hate drive by wire.Any one ever heard of http://www.brphotrods.com/Truck%20LS1.html
#10 | |
The pedal don't feel the same to me and Toyota had some problems with there's just taking off on you.I like everything simple as it cam be less to go wrong.
#12 | |
Cheyenne Super
control is one of them. I've herd 98 and up GM cars/trucks have a "black box" that records you're driving. GM does track cars with On Star installed. |
Pretty much any car 1996 and newer has a "black box"
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
The newer Tacoma has a recall on it the drive by wire sticks wide open.I heard about the black box on the c5 up corvettes.
#15 |
Low & Fast!
Good info...
#16 |
Garage wrench
yes. Even though a lot of that stuff is out of the average guys price range there are is a lot of good info and some innovative products that don't break the bank.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
#17 |
truck addict
yeah.. i have a scanner that can see all that stuff... i get my freinds with it all the time.. but its only the last 5 miles you drove.. mainly used for warrenty repair and accident investigation...
#18 | |
Cheyenne Super
I don't do well with electronic nannys... I still want an LSx, but only with an aftermarket or reprogrammed GM computer. You know, the easy thing to do would be putting the old cab and bed on the newer frame and drive train. |
#19 |
There is a kit now to run a distributor on a ls1 even carb intakes now.
#20 |
truck addict
i thought they ran seperate coil packs.. does the stock ls1 block have a hole for the dist.. i didnt think it did... i am curios to see how that setup works... any links to that?
#21 |
Hey guys, look at this link. It should answer any carbed/lsx questions.
http://www.ls1tech.com/forums/conver...-dist-ls1.html Last edited by thump16; 01-13-2009 at 01:07 PM. |
#22 |
truck addict
ok so your still running the coil packs with an msd6010 controler... then a carb on top... that sounds liek a really clean instail for my truck... i mean i can get a used lsx motor, tranny, ecu, harness, pulley system, the whole nine from a place near me called contemporary corvette for jsut under 3k... most of the vettes they part out have been in rear end colisions and they keep it in the car if you wanna hear it run... i looked at 8 engines yesterday all running, all under 20k miles... i think thats the next route im taking... maybe not this income tax time but definitly next year if its not done already
#23 |
Here are some pics
#24 |
1 more
#25 |
truck addict
yeah that looks like i will be doing that to the 87... just one question though... since i already have the tpi off an 85 firebird would it be easier to keep the fuel injection or switch it to carbed... im not saying use the firebird manifold but use the complete lsx fuel delivery system or get a carbd intake and all that? i personally would liek to keep it FI because then i could use the plastic covers and all but if it would be easier to switch it i would if i had to.. waht do you think?
