67 c10 283
Hello everyone,
I have a c10 1967 w/ stock 283. Going to freshen up the motor and stick with the 283. Even though a crate 350 is cheaper, everyone has 350s and I just love that little 4.6L. Couple of questions for the 283 gurus. Keep in mind this is not going to be raced. Just daily driver/cruiser. Here is a starting list of parts I am thinking of. Please let me know your thoughts as this is the first 283 I've done. - COMP Cams CL12-242-2 - GM Performance 12558060 - MagnaFlow 16643 - Summit SUM-G9006-9 These Vortec heads any good? On Summit site it reads They require the use of a Vortec-style intake and self-aligning rocker arms Summit site says they will fit a 67 283. Anyone have any experience with these heads? Or any suggestions on cam choice, heads, or exhaust? Any thoughts/ideas would be much appreciated. I'm ready to get to work. Thanks!! ![]() |
![]() Join Date: Nov 2008
Re: 67 c10 283
Can you list the specs on the parts so people don't have to look them up?
Re: 67 c10 283
Sure!
- COMP Cams CL12-242-2 (Cam Kit) Part Number: CCA-CL12-242-2 Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 1,600-5,800 Intake Duration at 050 inch Lift: 224 Exhaust Duration at 050 inch Lift: 230 Duration at 050 inch Lift: 224 int./230 exh. Advertised Intake Duration: 268 Advertised Exhaust Duration: 280 Advertised Duration: 268 int./280 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.477 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.480 in. Valve Lift with Factory Rocker Arm Ratio: 0.477 int./0.480 exh. lift Lobe Separation (degrees): 110 Intake Valve Lash: 0.000 in. Exhaust Valve Lash: 0.000 in. - GM Performance 12558060 (Heads) Part Number: NAL-12558060 Cylinder Head Style: Assembled Cylinder Head Material: Cast iron Cylinder Head Finish: Natural Combustion Chamber Volume (cc): 64 CNC-Machined Combustion Chamber: No Intake Runner Volume (cc): 170cc CNC-Machined Intake Runner: No CNC-Machined Exhaust Runner: No Intake Port Location: Standard Exhaust Port Shape: Square Exhaust Port Location: Standard Spark Plug Style: Straight Intake Valves Included: Yes Intake Valve Diameter (in): 1.940 in. Exhaust Valves Included: Yes Exhaust Valve Diameter (in): 1.500 in. Valve Springs Included: Yes Outside Diameter of Outer Spring (in): 1.250 in. Damper Spring Included: No Number of Springs Per Valve: Single Retainers Included: Yes Retainer Material: Steel Locks Included: Yes Lock Style: 7 degree Valve Stem Seals Included: Yes Valve Stem Seal Style: Umbrella Rocker Arm Studs Included: Yes Rocker Arm Nut Thread Size: 3/8-24 in. Rocker Arms Included: No Rocker Arm Nuts Included: No Guideplates Included: No Accessory Bolt Holes Drilled: Yes Valve Guides Included: Yes Valve Guide Material: Bronze Valve Seats Machined: No Valve Seat Material: Steel Steam Holes Drilled: No Oiling Style: Through pushrod Machined for O-Ring: No Heat Crossover: No Quantity: Sold individually. Notes: Requires Vortec-style intake manifold for installation. - MagnaFlow 16643 (Exhaust System) Part Number: MPE-16643 Exit Quantity: Dual Exit Location: Split rear System Material: Stainless steel System Finish: Natural System Style: Crossmember back Muffler Included: Yes Muffler Quantity: Two Muffler Configuration: Single inlet/Single outlet Muffler Style: Turbo Exhaust Type: Dual Hardware Included: Yes Inlet Quantity: Dual Intermediate Pipe Diameter (in): 2.500 in. Tailpipe Diameter (in): 2.500 in. - HED-69096 (Headers) Part Number: HED-69096 Header Style: Full-length Header Material: Steel Header Finish: Ceramic coated Primary Tube Diameter (in): 1 5/8 in. Collector Attachment: Ball and socket flange Collector Diameter: 3.000 in. Tuned: No Primary Tube Gauge: 18-gauge Flange Style: Standard Flange Thickness (in): 1/4 in. Bolts/Studs Included: Yes Gaskets Included: Yes Reducers Included: Yes Y-Pipe Included: No Quantity: Sold as a pair. Thanks in Advance!! ![]() |
Re: 67 c10 283
I have a set of iron eagle dart heads which are in the same ballpark as the vortecs if you put the bigger 2.02/1.60 valves in it and i had that same exact cam but later changed it.
If you really want power convert to a hydraulic roller cam with around 235-240 degrees duration and buy the vortec heads from scoggin dickey which already have screw in rocker studs and larger valves. For a headers I would go to a 1 5/8 to 1 3/4 stepped primary full length header.Lastly, get an edelbrock rpm air gap manifold for vortec heads. My Monte Carlo with this similar combo but with dart heads puts 350 HP to the rear wheels. |
Re: 67 c10 283
Though mine wasn't a 283.......second thought keep the cam
Re: 67 c10 283
what is the use intended for the truck? That cam might be a little big for a 283 unless it is greared down (4.10-4.56 range). It is really easy to over cam a 283, try to keep the duration at 216 at .50 or less especially if it has the stock gearing.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin ![]() 67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts) |
Re: 67 c10 283
Thanks for everyones reply. Opinions/Thoughts are much appreciated. Intended use for the truck is aggressive daily driver. Is there somewhere to look up what my stock duration is on my engine?
Thanks!! ![]() |
Re: 67 c10 283
Glad to here you`re keeping the 283.Is you`re truck manual or automatic?I think what I`d do is research the specs on the performance 283s and duplicate that.Like the 263horse 283.You can always bump it up a notch for a bit more power.The 283 likes the hign side of rpms and you may want to go for more bottom end than upper with a cam.I think with the weight o a truck,that`s where you`ll feel the modt improvement.Go for torque and the rest will follow,IMO.
Re: 67 c10 283
Thanks man! To answer your question, it's a 3 speed manual. I'll check the specs on the ho 283's you mentioned. Never thought of that. I have had friends in the past put way too much cam in their engines and they sound great but are about useless unless you are at 4K RPM so I will go for the most torque I can get out of her! I'll keep you posted to my progress.
Thanks again! ![]() |
