01-10-2009, 01:54 AM | #1 |
Active Member
How to remove wire connectors
How do you remove the male spade conectors from the bulkhead connection. The ignition wire that come out of the firewall broke off at the bulkhead connector. I pulled the bulkhead apart but I can't get the male spade to come out to fix the wire. Thanks
01-10-2009, 09:34 AM | #2 |
I am a Referee of life.
Re: How to remove wire connectors
Look at it very carefully.You can put a very small screwdriver in the connector and slip the spade right out.Awwwww heck
Here's a better link it's about HEI but tells how to replace the resistor wire which is the part you want to read andmember "shifty" even gives a part # for the spade terminal you need.Buy extry so you don't have to go back.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-10-2009, 12:04 PM | #3 |
That is the terminal with the little "leg" on it right ? If so, just use a side cutter to snip the leg at the top where it connects to the larger part. It will slip right out. Get a replacemnt terminal from NAPA. After you get it fixed, fill the holes on the back side with some liquid electical tape stuff to keep it sealed up.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
01-10-2009, 12:16 PM | #4 |
01-10-2009, 05:51 PM | #5 |
Active Member
Thanks guys worked well
