Old 01-10-2009, 01:06 PM   #1
68c10owner
68c10owner's Avatar
another gauge question
I found another set of gauges for my 84 that came from another 84 truck. The guy does not gaurantee that they work. Is there way to test them out of the vehicle? Are they rebuildable if they don`t work?
Anthony
68c10owner is offline   Reply With Quote
Old 01-10-2009, 01:41 PM   #2
shadetree
shadetree's Avatar
Re: another gauge question
Yes, the gauges can be tested, in or out of the truck. Each one needs different data (speedo needs a mechanical twist/heat gauge needs a signal from a correct sending unit/ect). I've never rebuilt a gauge, as junkyard replacements are cheap, and factory gauges are sealed.
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 01-10-2009, 02:44 PM   #3
68c10owner
68c10owner's Avatar
Thanks. I`ve never messed with them and would hate to buy a set of gauges only to have them not work. They look clean in the pictures and hopefully I can get them cheap. I also found a clock to put in the cluster if i end up with it. I was going to just go with Autometer but I`ve decided to just use the factory stuff.
Anthony
Old 01-12-2009, 07:52 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You can rebuild them, but they cost more than it would if you found one that worked. I personally used to sell these and they are easy to check if you have a truck there. I wouldn't buy one if they owner can't say if it works or not, unless it was free.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-13-2009, 05:12 AM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Originally Posted by Captkaos View Post
You can rebuild them, but they cost more than it would if you found one that worked. I wouldn't buy one if they owner can't say if it works or not, unless it was free.
Ya x2. I have never spent money on rebuilding just found another good set. I wouldn't give money unless I know that the gauges work just my .02 cents bud!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 01-13-2009, 02:34 PM   #6
68c10owner
68c10owner's Avatar
Thanks guys. I decided to pass on them. I don`t really have the money to be buying gauges now anyway. I just though that since they were unde $50 I might pick them up but I`ll wait. Whats a fair price for a gauranteed set of factory gauges?
Anthony
