01-11-2009, 06:47 PM | #1 |
67-72 radiator Support Question
My question is whatis the differnce between a rad. support for a 67-68 and a 69-72? i got a bunch of extra parts with my truck and was trying to figure out if the rad.support i got was for a 67-68 or a 69-72. any help and pictures would be greatly appricated.
Thank you, Phil |
01-11-2009, 07:04 PM | #2 |
The Older Generation
Re: 67-72 radiator Support Question
67-68 core support has separate headlight buckets and 69-72 headlight buckets are spot welded to the core support. You can make a 67-68 support out of a 69-72 by removing the headlight buckets and putting the square holes in it for the headlight adjusters. If you have both kinds it is easy to see the difference and what you have to do to convert it. I guess you could go the other way too and add the weld on buckets to the 67-68 to make a 69-72 out of it... Here is a pic of a 67-68 support. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-11-2009 at 07:09 PM. Reason: added pic |
01-11-2009, 07:15 PM | #3 |
so the general shape there is no difference, the only difference is in the headlight mounting area.
01-11-2009, 08:39 PM | #4 |
Correct... LockDoc
01-11-2009, 08:55 PM | #5 |
Gone to greener pastures
Here's the one I recently installed on my '69.
Don't mind the mess, it's a "work in progress."
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
01-12-2009, 12:52 PM | #6 |
The 67-68 also has threaded holes along the bottom edge to mount the splash shield (a small difference that is easy to miss until you start to install the shield!)
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 01-12-2009 at 12:53 PM. |
01-12-2009, 01:21 PM | #7 |
Recovering 67-72 Addict
I think that there may be some small differences to the contours too. I once tried to mount a factory auxiliary battery tray to a 68 core support and could not get it to properly sit on the core support. It is also very possible that it was just me...
Compare the driver's side of LockDocs's picture with El Jay's picture. They look different to me. It probably doesn't matter unless you want to put in a factory auxiliary battery tray.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" Last edited by breeh; 01-12-2009 at 01:28 PM. Reason: Added more info |
