question about porterbuilt dropmember
if you order a porterbuilt drop member does it come ready for the motor. everyone says it is a bolt in unit. do you have to weld the tabs in for the motor mounts or they already installed. thanks guys
Re: question about porterbuilt dropmember
the tabs are already welded on, the unit requires no welding at all.
67-72 parts collector,…
![]() Join Date: Nov 2002
The only welding would be for the notch for the rack steering/tie rods to clear the frame.
Give Nathan Porter (porterbuilt) a shout by Pm'ing him directly.
As mentioned, there is no welding required on the Dropmember itself. The only welding required it in regards to the notches in the frame for rack and pinion clearance.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
