Old 01-12-2009, 09:26 PM   #1
drewfever1020
alternator belt help!
i tighten the belt on my alternator and its good but after a few drives it gets loose!
why is that? do i need new pullys? and when i punch it, i can smell the rubber from the belts? why?
drewfever1020 is offline   Reply With Quote
Old 01-12-2009, 09:46 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: alternator belt help!
Unless your adjustment is slipping, you have a bad belt.
I'm a huge fan of Gates brand or Dayco Top Cog belts myself. They never stretch for me after I put them on.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-12-2009, 10:57 PM   #3
drewfever1020
but it couldnt be my adjustment cuz i tighten the hell out of it
Old 01-12-2009, 11:00 PM   #4
Tx Firefighter
Well, tight or not, is the adjustment slipping ? Mark it someway and see if it moves over time. Is the bracket cracked ?
Old 01-13-2009, 06:24 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
One thing I see all the time is people who think just because a belt is still together and isn't cracked that it is good.A V bely runs on the V.If it's in the bottom of the pulley tightening it will only help for a short time.
\V/ the sides should contact and be slightly pulled down into the V of the pulley.If the belt goes all the way to the bottom of the pulley it is either the wrong width belt or it's worn out.Unless you have deep groove pulleys the belt should be even with the outer diameter of the pulley or just slightly below.One way of telling if the belt is bad is if the V is glazed.
The other side of this is that a belt that is overtightened will place undue stress on the bearings supporting the pulleys.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
