01-13-2009, 09:16 PM | #1 |
bbc headers
I'm in need of some new headers and wondering which ones you guys are running on you're big block. I bought the tubular mounts with energy suspension polyurathane mounts and i think they were for small block. My headers were hitting the lower a-frame on one side and put a pretty good crease in them. So i'm replacing my mounts with solid ones that look to be about 1/2 to 1" longer which will help my new headers miss my a-frame. I'm not going to use the cheap hooker headers because one of the primary tubes hit my oil pan. I'm thinking about trying to find some with 2" primaries with a 3 1/2 collector. Do you guys think that these will be to big for my high reving 431 bb?
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
01-15-2009, 08:36 AM | #2 |
Re: bbc headers
I don't know how well mine would fit a truck with the stock front end and mounts since I have mustang II and motor plates but I have hooker super comps from a malibu. I had a couple of the tubes slightly modified for extra clearance.
I wish you were closer I would let you try these
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
01-15-2009, 09:52 AM | #3 |
Ready to go fast!!
Re: bbc headers
i have the cheap set of hookers and i just cut that tube that hit my oil pan and shortend it
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded |
01-15-2009, 12:33 PM | #4 |
Re: bbc headers
I have never tried hedmans on a bb but they usually fit well.
01-15-2009, 12:51 PM | #5 |
Re: bbc headers
I run 2" Hooker Super Comps with a Moroso kick out sump oilpan and have no issues with tubes touching.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
01-15-2009, 06:22 PM | #6 |
Re: bbc headers
i have hedmans and they do fit pretty good, but just wanting bigger primary tubes with larger collector and hedman doesn't make them to fit our trucks. I'm leaning on buying the hooker supercomps for a malibu like dj and regan are suggesting. Wish i could try your's dj. Anybody know how much shorter they are compared to the supercomps that are made for our trucks? I would like them to be up a little bit more, but if they are to much shorter then i would have to redo my exhaust. thanks for the help.
01-15-2009, 06:19 PM | #7 |
Addicted to Chevy
Re: bbc headers
doug thorley tri-ys are good for SBC.... dont know about BBC
01-23-2009, 05:49 PM | #8 |
Registered Mail
Re: bbc headers
I have the "Tight Tubes" they are by headman I think and are a little expensive for the size of them I figure, but they fit awesome, with no clearance issues. and have heavy wall 2" primaries and a 3" collector. they are shorties, but I need them since I am bagged. but this way since I am running dual 3" exhaust i figure a 3" collector is fine.
and also since they are shorties, i can run my exhaust in the frame rails.
'67 chev 496, lwb to swb, bagged - pro street project |
01-23-2009, 05:56 PM | #9 |
Re: bbc headers
I have a set of Stans 2" try Y's for 73-87 BBC That fit perfect. I also used the 73' up motor mounts.
http://www.stans-headers.com/
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
01-23-2009, 06:17 PM | #10 |
Re: bbc headers
those stan headers look very nice, but where they merge into single pipes looks like they would be restrictive then they yet merge into a small collector. I guess they help with pulling exhaust out?
01-25-2009, 10:12 PM | #11 |
Re: bbc headers
Called jet hot and they are having a 30% sale on their coated headers. Told me that they would be $545 and i wouldn't have to pay for shipping being that they have a facility here in oklahoma city. But as usual i'm a day late, they are sold out of the supercomps that fit our trucks and the chevelle headers. That would of been a savings over $200!!! dang it....
04-10-2009, 10:08 PM | #12 |
Re: bbc headers
Just ordered my headers today. they are the supercomps for our trucks. i'll post pictures asap. i ordered them thru jet hot, couldn't get the 30% off though. after tax and everthing they were $840 ouch!!!! but tired of trying to find these damn things on sale. same price thru summit or jegs, but has better coatings.
05-06-2009, 02:42 PM | #13 |
Ready to go fast!!
Re: bbc headers
sorry to here the hair pulling news!!! man thats a pretty fast truck you got there... what kinda compression and stuff you runnin? is your truck lightend up any?
05-19-2009, 05:39 PM | #14 |
Re: bbc headers
Just got off the phone with jet hot and they still haven't received my headers from hooker. They then said that they may not receive them until the 26th of may. So i called hooker myself and the lady that i talked to also said that they were still on back order. I ordered these damn things on the 14th of april. She also said that she will check with production and get back with me. So i thought that id go ahead and just cancel the hole thing so i called jet hot back. Then they told me that it would be 2weeks to get my money credited back to my account. So if i wait to get my money back that long i might get my headers by then... I'll never do business with these 2 companies again...
05-21-2009, 12:49 AM | #15 |
Re: bbc headers
Im running the hooker super comp 2 tubes with 3 1/2 collectors coated headers on my 1972 blazer chassis and had to trim the hell out of booth frame rails on top. The plus side for me was I moved my engine back and down and with around 4 plus inches of drop and 26.5 tall tires I still have 10 inches to the ground from the collector. I have used chevelle headers in the past with some luck but after fitting these, im very happy. I will say putting a 598 talldeck with drag pan,bowtie prostock heads,tall valve covers and a victor intake into this stock front chassis was a little more than a 1 day job but the look is right on.My 4 inch cowl hood still gives me 2 plus inches over my air cleaner and my engine is 38 inches from pan to air cleaner lid.
07-03-2009, 06:20 PM | #16 |
Re: bbc headers
Well i canceled my order with jet hot because of hooker not producing any headers. I received my money back and ordered a set through summit and received them today. This is what i should of done to begin with... Anyways, on the passengerside, one of the primary's hits my front crossmember. Should i grind the crossmember down or dimple the header? It doesn't need much at all. I already moved the motor back as far as i could without redrilling my motor mounts. I'll install the other side tomorrow. I tried to install it today, but ran out of patience. Looks like i'm going to have to remove the oil filter to allow me enough room to swing them in there. Once i have these things fitting, i'm going to take them to jet hot here in okc and have them coated. They said that they will give me a pretty good discount. Also, it looks like i'm going to have to replace my transmission crossmember with a tubular one.. Has anyone else had to do this? Also what one do you guys recommend?
07-06-2009, 05:34 PM | #17 |
Hay Team!!
Re: bbc headers
Hey man...sorry you had some bad luck here. Why are you needing to change your tranny mount?
If it were me....(and the OKC farmtruck did the same thing) I would just grind for clearance on the frame. That way you are not taking a hammer to your brand new headers. It's just me tho. Other people will do it their own way but dimpling the header I'm sure will be just fine also.
1972 Chevrolet Cheyenne LWB "Orange and White" 8) |
07-06-2009, 05:41 PM | #18 |
Re: bbc headers
The supercomps don't hang as low as the hedmans that i had. Also, these headers are quite abit longer and come pretty close to the tranny crossmember. From the looks of it, i won't be able to run my exhaust below or above it because the exhaust tubing wont bend that short of an angle that quick..
07-06-2009, 05:45 PM | #19 |
Hay Team!!
Re: bbc headers
I hear ya.....wow.......I'm having the headache myself right now with brakes.....
07-22-2009, 11:20 PM | #20 |
Re: bbc headers
Installed new supercomps yesterday. Had to buy a new transmission crossmember in order for exhaust with new cut outs to clear. Here's a few pictures....
07-23-2009, 07:23 AM | #21 |
Re: bbc headers
Looks nice man. I doubt ill be spending that much on headers when time comes. Probly go with the regular hooker comp. love the truck man.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
07-23-2009, 09:16 PM | #22 |
Re: bbc headers
Thanks, i take it that you ended up keeping your truck? You also have a nice project.
07-23-2009, 09:57 AM | #23 |
Re: bbc headers
Glad to see you finally got them in.
07-23-2009, 09:18 PM | #24 |
Re: bbc headers
thanks drag truck, especially for your help on picking a crossmember.. I ended up finding one almost just like yours thru trans dapt. Summit racing has them.
09-16-2009, 12:07 AM | #25 |
Re: bbc headers
You might consider reinforcing your crossmember.
http://67-72chevytrucks.com/vboard/s....php?p=3250018 http://67-72chevytrucks.com/vboard/s...d.php?t=266474 http://67-72chevytrucks.com/vboard/s...d.php?t=318690 Last edited by gene_ensor; 09-16-2009 at 12:09 AM. |
