Old 01-14-2009, 12:43 AM   #1
pcorriveau951
pcorriveau951's Avatar
Air ride question
Ok for those of you who are on bags with stock frame(no z's) my question is fully inflated how high does your front fender sit off the ground (wheel arch to ground)? also what size rim and tire combo are you running? and what size drop spindles are you running?
Thank you, Phil
pcorriveau951 is offline   Reply With Quote
Old 01-14-2009, 02:53 PM   #2
pcorriveau951
Re: Air ride question
ttt
Old 01-14-2009, 05:10 PM   #3
hotrodhomi
hotrodhomi's Avatar
Thank you, Phil
This is going to depend on your tire size. I'm not sure about the measurement you are looking for but my a arms touch the ground when dropped.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 01-15-2009, 01:41 AM   #4
pcorriveau951
hotrodhomi, what im looking for is the measurement from the ground to the front fender when fully inflated
Old 01-15-2009, 10:34 AM   #5
Shane
Shane's Avatar
that still depends on your tire size ....
Shane is offline   Reply With Quote
Old 01-15-2009, 12:12 PM   #6
mycool72
mycool72's Avatar
I guess we could just make some #'s up....
mycool72 is offline   Reply With Quote
Old 01-15-2009, 02:09 PM   #7
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
You could + or - the stroke of the bag your going to use to roughly determine where the body will wind up.A little project Im working on, wanted to lay frame but also wanted max travel so a little measuring and mock up determined where the bags should sit.
sneakysnake is offline   Reply With Quote
Old 01-15-2009, 03:50 PM   #8
theyammieguy
accepting donations
theyammieguy's Avatar
23 pages of bagged c-10's in the suspension section. I've looked through all of them several times for ideas.
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 01-21-2009, 06:19 PM   #9
wdrthird
wdrthird's Avatar
Heres my 71 layed out. Its got 2.5 drop spindles and the wheels up front are 20x8.5 with 5.25 backspacing and the tires are 255/35/R20's. The wheels in back are 22x9.5 with 6.25 backspacing and the tires are 265/35/R22's.
wdrthird is offline   Reply With Quote
Old 01-21-2009, 06:21 PM   #10
wdrthird
wdrthird's Avatar
1. All the way up. 2. Front wheel arch. 3. Rear wheel arch.
Old 01-21-2009, 06:23 PM   #11
wdrthird
wdrthird's Avatar
1. Ride height. 2. Front wheel arch. 3. Rear wheel arch.
Old 01-21-2009, 06:24 PM   #12
wdrthird
wdrthird's Avatar
1. All the way down. 2. Front wheel arch. 3. Rear wheel arch. Hope this helps.
Dusty
Old 01-21-2009, 07:31 PM   #13
Kayotic
Kayotic's Avatar
Alright wdrthird, How'd you do it?
I don't want to squash this thread, do you have a build up some where?
The only travel I have now is when the tires deflate daily.
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 01-21-2009, 08:39 PM   #14
wdrthird
wdrthird's Avatar
Sorry, no build thread. First I gotta say, the air ride was already on my truck when I bought it, but the previous owner was one of my closest friends so I watched/helped with the build. The front is a basic setup, but instead of using cups on the lower control arms to mount the bags, the top of the factory lower control arm was cut out enough for the bag to pass through without rubbing, then a plate was welded to the bottom of the lower control arm and the bag bolts directly to that. The back has a homemade 4 link with a panhard bar. Theres a pretty big notch up through the bed to get down over the 22's. The bed floor was raised 5 inchs to make room for the fuel cell. The back of the cab had to be notched slightly to make clearance for the drive shaft. The exhaust runs through the crossmember to keep it from dragging. Its far from laying frame, but it will set the stock front crossmember on the ground. It still has the stock inner fenders up front. I think I have some pics of underneath the truck from the last time I had it up on the lift, but they're on my other computer, if I can get it to work long enough I'll try to dig them up.
Old 01-21-2009, 08:18 PM   #15
XXL
Señor Member
XXL's Avatar
We have a Suspension forum where you might get a lot more information on this topic.
XXL is offline   Reply With Quote
Old 01-21-2009, 09:56 PM   #16
68 short step
sweet set-up, where in OK are ya?
68 short step is offline   Reply With Quote
Old 01-21-2009, 10:59 PM   #17
wdrthird
wdrthird's Avatar
Thanks man. Im up in Ponca City, near the Kansas border.
Old 01-21-2009, 11:37 PM   #18
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Mine is in winter storage, so no access right now. I wish mine was as low as WDRTHIRD.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 01-22-2009, 03:22 AM   #19
pcorriveau951
wdrthird, thank you very much that is exactly what i was looking for.
Old 01-22-2009, 11:45 AM   #20
Kayotic
Kayotic's Avatar
I would also like to thank wdrthird. Your truck will be a role model to many here; for you have excatly what owners are looking for, including myself.
And your writting was clear and easy to understand - even though I haven't seen any damn detail pictures. J/K.
Thanks for the quick responce and answering the original question.
Atlanta Craigslist
Old 01-22-2009, 02:23 PM   #21
wdrthird
wdrthird's Avatar
No problem guys, glad I could help.
Old 01-22-2009, 03:18 PM   #22
hotrodhomi
hotrodhomi's Avatar
What did you do to drop your truck wdrthird? I just checked mine and I only get 23.5" and 24" when aired out. I ran your tire size against mine and yours are .4" taller in the front and 1.3" taller in the rear. You must have a step notch because my rear diff touches the underside of the bed.
'66 impala ht
Old 01-22-2009, 07:15 PM   #23
wdrthird
wdrthird's Avatar
Yes, mine has a step notch. The difference in the front might be the way the bags are mounted, Im not using cups on top of the LCA, my bags are bolted to a plate welded to the bottom of the LCA.
Old 01-22-2009, 09:22 PM   #24
pcorriveau951
wdrthird, i agree with kayotic we need some picture of your suspension!!!!
Old 01-23-2009, 11:04 AM   #25
wdrthird
wdrthird's Avatar
Heres some pics, they're not the greatest, but they're the best I have for now. The first one is of the front crossmember and LCA with the truck aired down. The second one is of the front bag mount. The third and fourth ones are the step notch and rear bag/mount taken from the front looking towards the rear of the truck. The last one is just for comparison, stock vs. bagged.
'02 Harley Davidson XL1200C, Chrome everything
'99 Tahoe, Removed trim/emblems/roofrack/runningboards, Custom grill, Smooth bumper, Lowered 2" on 20's
'97 Jeep TJ, 2" lift, 32x11.50's
'71 C10 Short Fleet, 454, TH400, Vintage Air, 4 Wheel discs, Posi, New bed sides/rockers/bumpers, Relocated tank, Bagged, Step notch, 20/22's
http://www.myspace.com/ndweedz
http://www.youtube.com/user/wdrthird
"My lugnuts require more torque than your Honda makes"
