Old 01-14-2009, 07:54 PM   #1
short step
GM alt wires
What are the wires on a 89 alt for 2 red , brn & brn/w
bob
short step is offline   Reply With Quote
Old 01-14-2009, 09:28 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: GM alt wires
This should be the alternator you are referring to called a CS style. The diagram is showing how to convert one to the older chevy trucks. When you ask what wires go where by color it can be deceiving because different models used different color wires. Below is the terminals and where the wires go from them.
"P" Terminal (Phase Connection) - This terminal sends a signal to a relay, frequency sensing tachometer, or computer indicating alternator speed. This terminal may not be used - this is normal.
"L" Terminal (Charge Light) - This terminal is fed from the ignition through the charge light on the dash. This connection turns the alternator "on". Without a signal to turn "on", the alternator will not charge. However the "I" terminal may be used to turn this alternator "on", as described, instead of the "L" terminal. Please note that if there is a connection on the "I" terminal there will be NO connection on the "L" terminal.
"I" Terminal (Ignition) - This terminal is fed directly from the ignition switch to turn the alternator "on". Without a signal to turn the alternator "on", the alternator will not charge. However the "L" terminal may be used to turn this alternator "on", as described, instead of the "I" terminal. Please note that if there is a connection on the "L" terminal there will be NO connection on the "I" terminal. If there is a connection on the "L" terminal AND the "I" Terminal THEN the "I" terminal is NOT an "I" terminal but an "F" terminal (confused yet??).
"F" Terminal (Field Monitor) - This terminal sends a signal to the computer telling it how much field current is flowing (therefore the computer knows how hard the alternator is working). This terminal is not always used AND can only be used if the alternator is turned on by the "L" terminal.
"S" Terminal (Battery Sense Connection) - This terminal is larger than the others and provides the alternator with a precise battery voltage reading however, this connection may not used. When not used, the alternator will automatically sense battery voltage at the battery post.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-14-2009, 10:41 PM   #3
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: GM alt wires
confused as heck. i will save this as i am not too far from having to do this.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-15-2009, 02:05 AM   #4
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: GM alt wires
There is another way to wire it with out using the stock GM wiring at all. I'll take pics of how mine is wired, but we didn't use the stork wiring harness and voltage regulator on mine. The cab get's it's power off a fuse block that's on my batt. and the alt is wired up differently..
I'll grab pics friday/saturday.
texanidiot25 is offline   Reply With Quote
