01-15-2009, 09:53 AM | #1 |
axle tube leak
Guys, i am pretty sure i have a leak on the passenger side of my rear diff. where the axle tube meets the central housing, not a huge leak, just a drop here and there, i will double check to make sure it isnt the fill hole leaking down and around. can this be welded to stop the leak?, i am only a beginner welder and am not sure if you can weld steel to cast iron? the only other things i can think of is A - get new housing or B - clean the joint, use some silicone or gasket maker on the outside of the joint, and go over it with a few coats of paint to help stop the leak. the rear is a 3:08 posi, that i will be taking in to get rebuilt soon, just wondering if this can be fixed or should i get a new housing. the tube does not appear to be seperating from the housing.
Thanks in advance.
'55 3100 2nd series short-bed stepside '70 Corvette coupe stingray '71 Chevelle 2-dr coupe SS clone '71 C10 long-bed fleetside '83 long-haired brunette wife |
01-15-2009, 10:44 AM | #2 |
Re: axle tube leak
its not unusual to get a leak there// it can be welded some guys use stuff like jb weld forget the sillycone//if you're taking it in for rebuild see if they'll do up both tubes for you
01-15-2009, 03:55 PM | #3 |
Re: axle tube leak
Have you checked to make sure the vent is open? A plugged vent will cause pressure to build up in the differential and cause lube to be pushed out.
As suggested when the other work is done have both tubes welded up. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-15-2009, 04:14 PM | #4 |
Spanked once
Re: axle tube leak
There is a nickle rod you can get to do this , but I would not do it until the housing is empty and clean.
The ole 350 budget build. |
01-15-2009, 04:21 PM | #5 |
Re: axle tube leak
I agree with the vent and checking to see if other things are leaking as stated above, but I would then check to see if the housing is bent....causing it to leak. On a C-clip axle it isn't hard to pull the shafts and then "eyeball" down the housing. When axle tubes are pressed into the center section they have a bead of silicone in them to seal them up, and it's possible that this has deteriorated. Rather than welding it up on the outside, I'd pull the carrier, clean it really good with brake cleaner, and then silicone it on the inside where the tube meets the center section.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
01-15-2009, 04:41 PM | #6 |
Re: axle tube leak
yeah i cleaned the vent about a year ago, i will double check and make sure that nothing has clogged it since. thanks for the info guys.
01-15-2009, 10:36 PM | #7 |
Re: axle tube leak
i just had mine welded for strength for drag racing and i searched around alot on how to do it and what to use. everything i saw from the average hot rod builder said to use a nickel rod, then i got on the miller welders website and in their FAQ section a guy asked about welding the tubes on a mustang, they told him to use a stainless rod. that's what i had mine done with, came out great.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
