01-16-2009, 04:31 PM | #1 |
steering column choices
i have a 72 c10 longbed with what i think, if i remember what the PO told me, an '87? cougar tilt column in it. the tilt is all wonky. i would like to replace the column but i'm not sure what years from what trucks will work with it. or am i better off just trying to fix the one that's on there?
1972 Chevy C10 Long Bed 454 Big Block Turbo 400 3 Speed Dual Flowmaster Edelbrock 750 Carb Power Steering Disc front brakes Drum rear brakes B&M Floor Shifter |
01-16-2009, 04:54 PM | #2 |
Re: steering column choices
you're best off going with an original 67-72 unit, or one from a chevy van up to around 1980?? will also work with minimal modification. There are more expensive aftermarket units also...
hopefully, someone will chime in with more specifics on the van columns, but the tilt versions are commonly used in these trucks.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project Last edited by bigvinnie; 01-16-2009 at 05:00 PM. |
01-16-2009, 05:05 PM | #3 |
yeah i've seen those used. wanted to make sure it's not too much of a pain to install. as far as fabricating goes. difficult to find the 72's but easily found the van column.
01-16-2009, 08:20 PM | #4 |
Wow, a cougar tilt column?
Gotta get some pics for that one.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
01-16-2009, 08:49 PM | #5 |
