Old 01-17-2009, 04:35 AM   #1
Wilson_
Wilson_'s Avatar
Big window to Small window
My truck is a 67 with a small back window and the cab I have has tons of rust in the roof, rain gutters, entire floor, rockers, cab corners,fire wall, ect
I can only find clean big back window cabs for sale granted they need rocker repair but I would like to keep the small back window.
Has anyone done this before? Is it to much work?
Thoughts?
Northern California Group
Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby
Wilson_ is offline   Reply With Quote
Old 01-17-2009, 08:04 AM   #2
lax54650
Re: Big window to Small window
anything is possible. with the work involved i would look hard and seriously at finding a small window cab they are out there or settle for a big window. too much work for me. jmho
lax54650 is offline   Reply With Quote
Old 01-17-2009, 12:26 PM   #3
Hart_Rod
Hart_Rod's Avatar
Got any measurements? Are the windows the same height? I know the width is different, but if the height is the same, I don't think it would be to bad.
Hart_Rod is offline   Reply With Quote
Old 01-17-2009, 12:29 PM   #4
big_al_71
big_al_71's Avatar
Anything is possible with a plasma cutter and a welder.....Even thou I dont know how to weld
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-17-2009, 02:26 PM   #5
Willys47
Willys47's Avatar
maybe think of it this way make the truck your hobby that way it will not be work and it will be something fun.Thats how I look at it I have a new floor in my truck, side kicks, rockers ,cab corners, repaird my fenders ya I could have just bought new ones but I have the originals to the truck still I learnd lots. Hay it's metal if you do it wrong just cut it apart and do it again,it's fun not work and in the end you can say with pride made in my back yard.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 01-17-2009, 03:20 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Rob,
The windows are different in both directions.
Wilson: It is doable but the double wall construction of the cab would make it tough. I would take it apart at the seam that goes across the top rear of the cab and below the rear window where there is a break in the body line.
LockDoc
Leon
Old 01-17-2009, 04:49 PM   #7
squirel
squirel's Avatar
just change the inner and outer skins of the roof The skins i put on my small window were form 71 check out my build site below for pictures of me changing mine
In some foreign language "merge" means to stop and turn your head left.
My build page
http://67chev.shawwebspace.ca/
squirel is offline   Reply With Quote
Old 01-17-2009, 09:04 PM   #8
Willys47
Willys47's Avatar
that looks like that build was fun for all see Wilson_ it can be done
Old 01-18-2009, 12:39 AM   #9
Hart_Rod
Hart_Rod's Avatar
Originally Posted by LockDoc View Post
Rob,
LockDoc
Shoulda figured it couldn't be that simple, . Does anyone have the measurements?
Old 01-18-2009, 03:42 PM   #10
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
If I think about it while Im at the shop today I can measure both for you
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 01-26-2009, 03:27 PM   #11
john
member #16
john's Avatar
Heres a big to small conversion. Courtesy of 67mater.
http://67-72chevytrucks.com/vboard/s...d.php?t=303622
john is offline   Reply With Quote
Old 01-17-2009, 10:11 PM   #12
mr48chev
mr48chev's Avatar
There are two ways to look at doing it. One would be to see if replacement panels for the back of the cab available for the 67 small window. Other than that it is either cut the inner and outer back panels out of the old cab and transfer them to the new cab or cut a large enough section out of the old cab to use as a filler for the big window space.
The first thing I would do is get the info needed to see exactly how the cab was assembled when new (how the pieces went together) and go from there.
Old 01-17-2009, 10:57 PM   #13
Number98
Prestige Worldwide
Number98's Avatar
Hey.... there are guys choppin Burbs in half and making Tahoe's on this board, that tells me that anything is possible!
Number98 is offline   Reply With Quote
Old 01-18-2009, 04:48 AM   #14
Wilson_
Wilson_'s Avatar
Cool thanks for the replies guys. The other way i was thinking of doing it would be to cut at the two front pillars and and some where under the back window.
and just swap roofs with the back window included?
We will see when i get the cabs over here.
Old 01-26-2009, 05:14 PM   #15
Wilson_
Wilson_'s Avatar
sweet thanks for the link!!!
