Old 01-17-2009, 06:10 PM   #1
minime's 68'
Help Vent Window
Does anyone know how to tighten the handle on the vent window. Mine is coming loose and have no idea how to tighten. Any Help is much appreciated
minime's 68' is offline   Reply With Quote
Old 01-17-2009, 08:53 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Help Vent Window
There should be a small rollpin that goes through the handle and through a hole in the shaft. If the handle isn't broken on either side where the pin goes through you may be able to remove the existing pin, drill the hole a little bigger and use the next size larger rollpin. You can also order a replacement handle from any parts vendor.
LockDoc
Leon
Old 01-19-2009, 11:09 PM   #3
minime's 68'
Thank you sooo much!!
Old 01-19-2009, 11:11 PM   #4
LockDoc
LockDoc's Avatar
No problem...
LockDoc
Leon
