engine assembly code
wanted to confirm that this motor is original 402 as the previous owner indicates. I have the assembly date code off the block from the deck just in front of the passenger side head, have a pick of the casting code also but it isn't legible until I can get it cleaned off. I'll post the pics, the assy code is T1223TKB. I'll post both pics as well maybe you have a better eye than I do.
![]() ![]() ![]() thanks, Dan ![]()
Dan Smith Colorado Springs, CO 71 GMC Custom Camper "Longhorn" 454, TH400 73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny "DON'T TREAD ON ME !!!" My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442 Last edited by hilandr452; 01-20-2009 at 01:53 AM. |
Moderator
![]() Join Date: May 2007
Re: engine assembly code
TKB suffix code= 1972 402 big block
OK, I just found that, it also lists 71 402 with 310 HP. so what does the T1223 stand for?
Dan Smith Colorado Springs, CO 71 GMC Custom Camper "Longhorn" 454, TH400 73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny "DON'T TREAD ON ME !!!" My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442 Last edited by hilandr452; 01-20-2009 at 02:31 AM. |
couple more pics
Dan Smith Colorado Springs, CO 71 GMC Custom Camper "Longhorn" 454, TH400 73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny "DON'T TREAD ON ME !!!" My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442 |
According to MorTec, if it's 3969854, which is what I'm seeing here, it could either be 70-72 402 or 69 396. What do you guys think? Probably original motor?
Dan
Dan Smith Colorado Springs, CO 71 GMC Custom Camper "Longhorn" 454, TH400 73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny "DON'T TREAD ON ME !!!" My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442 Last edited by hilandr452; 01-19-2009 at 05:15 PM. |
On the page where it explains the TKB code on nastyZ28 site it shows L-47 10,20,30 under comments. Anyone know what that means?
Dan
![]() Join Date: Feb 2004
Doesn't the T stand for Tall Deck?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Moderator
c-10, c-20, c-30. 1/2 ton, 3/4 ton, 1 ton trucks L-47 was the production code. it is probably the original engine. My 72 big block is a TKX suffix code, under comments it lists 20, and my truck is a C-20 3/4 ton
![]() Join Date: Jul 2007
The stamped numbers should match the numerical part of your trucks serial number if it is the original engine.
As those of who watched part or all of the Barrett-Jackson auction this weekend can attest. If they don't match it most likely shows that the block was swapped out at one time or other. If the engine and trans both are original to the truck both will have the same number as the cab and chassis. Last edited by mr48chev; 01-19-2009 at 05:28 PM. |
Cool, is the serial number part of the vin? Does this rule apply to GMC trucks as well?
Dan Smith Colorado Springs, CO 71 GMC Custom Camper "Longhorn" 454, TH400 73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny "DON'T TREAD ON ME !!!" My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442 Last edited by hilandr452; 01-19-2009 at 08:25 PM. |
Ok here's the SPID and what looks to me to be serial number plated on the door and door jamb. This indicates that it's not original then?
![]() ![]() ![]() If true I will be sad. Dan ![]()
its possible the engine was replaced under warranty for some reason, that would be close enough to factory for me
PROJECT CIRCUIT RIDER |
Does anyone have a link to a site that would allow me to decipher the vin code or assembly code for the motor for GMCs? I'm having trouble finding anything.
bump!!
#15 |
Moderator
Has the engine been decked? If so, I have heard that will remove the other numbers.
#16 |
Since the assembly date code T1223TKB was found on the deck, I don't think it was decked. According to a web site I found, the vin code is sometimes found in other locations, so I'll be trying to uncover it in the areas specified.
Dan ![]()
#17 |
bump
#18 |
one more bump
#19 |
![]() Join Date: Aug 2004
I think the partial VIN on the engine rule only applies to cars, not trucks. I bet it's original.
Someone here knows for sure...
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#20 |
They didn't put the VINs on truck engines. From the dates and codes you listed, it looks to line up. There is a cast date on the block under the passenger exhaust manifold. Check to see what this date says. I'll bet it's nov or dec of 71. Which would line up. But, from what you have already described, I think you have a match.
#21 |
I know they didn't put the entire vin code on the engines, but they did stamp the assembly date code, the suffix code-telling you the engine size, hp, vehicle type, and sometimes tranny and the production number of that particular style for the year, which is the last part of the vin and from what I've been told and have read from multiple sources, that is how you determine engine/body/frame matches. For this truck it would be 14211, which indicates that it is the 14, 211th truck built in that year. If you look up in one of the pictures I posted, it shows that code in smaller stamp letters on the deck just right of the assembly code. I'll repost the picture here with the caption below it so maybe some of what I just stated makes more sense.
![]() Stamped assembly code and portion of the “VIN” number on the front pad of the deck. This was found on a 402 block cast on 4/27/71. “TO5O4CLB” translates into a 402/300hp engine made at the Tonawanda factory (T). On May 4th (month 05, day 04) it was placed into a 1971 Chevelle and was mated to a Turbo–400 automatic transmission (CLB). The “11C166486” relates to the VIN and body style of the Chevelle. From the stamped engine assembly code and the block casting date we can tell that the engine block itself was cast and then 7 days later the fully assembled motor was placed into this vehicle.
#22 |
There is no, repeat no vin # stamped on a truck motor period.
72 Cheyenne Super 80 Silverado Blazer 2wd |
#23 |
OK, what you're saying is that it just doesn't come on trucks? Don't flame me, I'm just trying to clarify.
#24 |
I am just saying the info you already have is just about all the info you are going to get. There is not a for sure 100% guarentee way to tell if a 67-72 chevy truck has the original engine or not because THERE IS NO VIN # ANYWHERE ON A TRUCK MOTOR.
#25 |
Moderator
