01-21-2009, 01:40 PM | #1 |
still buypickupparts
Help Please Altenator questions
I have a 72 fleetside, the engine is a 1994 LT1, runs good, I have not run it to break in the motor yet, (waiting for this cold snap to move on) but I have the altenator wired as follows, the alt. battery post going to the battery. then there is a harness on the Alt from the LT1 wire harness. this harness has 1 wire connected for the plug. What my worry is looking in the 72 service manualin the electrical Body and Chassis section I see a fused wire 14 gage Black and white wire that is spiced into the unfused power wire going to the fuse block. this wire that is fused if I'm seeing this right should this wire be connected to the B+ post wire thats on my Alt.?
and also do I have the Alt connected correctly with just the LT1 harness connector and the Battery wire connected to the batt. is this all I need? I have not run the engine long enough to see if it charges the battery, also I dont know how to check that if I am to be honest about this all Please help me out to understand what I need Please
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
01-21-2009, 03:35 PM | #2 |
Re: Help Please Altenator questions
Need to know what alt. you are using? Stock 72 externally regulated, internally regulated SI series or CS series. Also do you want your ampmeter to work or are you switching to voltmeter?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
01-21-2009, 03:42 PM | #3 |
Old member
Crank the thruck up and put a volt meter on the battery anything over 12 volts it's charging.
Once you hook it up idle the truck up to around 2000RPM'S it should read about 14 volts maybe more if the battery is good.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-21-2009, 04:02 PM | #4 |
Neonlarry , yes I forgot to say the Alt. is for a 94 corvette 150amp, yes 150 amp. why did I go so big, I have no Clue. and yes I would like my factory amp gage to work
Andy4639, thanks as soon as the weather gets better and I put my fuse block back on this is how I will check it
01-21-2009, 05:48 PM | #5 |
can anyone else help me out here, I just want to know what to do here
01-21-2009, 05:57 PM | #6 |
Get a old of Street and Performance. They can answer any question you have. They do these swaps all the time. I believe you can google them or try hotrodlane.cc. You can also look at their site they have the Lt-1 diagrams. That is how I did it on mine. but then I did you painless wiring for part of it. Thye answered any and all questions I had when I put the LT-1 in my 67 C10.
Kerry
1967 C10 Got it back after three years Boy I sure missed Peppy 1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
01-21-2009, 06:00 PM | #7 |
member #16
The 4 amp fused 18 ga. b/w wire should go to the ammeter. There is also a 18 ga. black wire for the ammeter. see diagram. They should have nothing to do with your charging circuit, they just read amount of chg or dis. Are these the wires you see in the 72 service manual? If not disregard.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 01-21-2009 at 06:02 PM. |
01-21-2009, 06:03 PM | #8 |
so in the picture , the wire with the fuse closest to the fuse block, does that wire connect to the battery wire off the Alt? or does it plug into the LT1 Harness Alt Plug?
01-21-2009, 06:57 PM | #9 |
Who's got steelies?
The fuse on the solid black wire goes to the positive battery terminal, basically; and the black wire with white stripe fuse wire will go where the positive wire from the alternator feeds into the rest of the harness, basically. How much of your truck's original wiring are you using? Where have you spliced the new/old together?
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
