01-21-2009, 02:09 PM | #1 |
Need Brackets Laser or Plasma Cut in St. Louis MO
I need a shop or well skilled person to cut some traction bar brackets out of 3/8'' plate to attach my 1'' heim joints. Have the drawings complete, basically just a big shock tab, just need to find a shop in the St. Louis area to perform.
I tried cutting them with my plasma, but 3/8'' is just a little to much for it and I needed more grinding than I am willing to do. Any help is appriciated thanks guys
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
01-21-2009, 03:53 PM | #2 |
Re: Need Brackets Laser or Plasma Cut in St. Louis MO
speedway motors has quite a few mounting brackets in their cata;ogue
me, i 've always just used my trusty old jigsaw and cut my own
01-21-2009, 04:29 PM | #3 |
My biggest problem is I am using a 1'' heim joint, so the bracket will need to have a 1'' hole in it, most mounting tabs only go up to 3/4'' in hole size if that. These heims are huge.
I also tried a jigsaw on some 1/8'' plate I had and I was only able to cut about an 1'' before the teeth on the blade were gone, and it was a Bosch blade. I cant even imagine trying to cut 3/8'' thick plate with one.
01-21-2009, 04:46 PM | #4 |
Many ag related welding and fab shops can do that sort of work. It may cost a bit more as you have what they would consider to be a small job by their standards. Otherwise there may be a rod shop in the area that can do the job.
Locally there is/was a guy who was cutting out pieces for modified Jeeps and selling them. There is also a guy In the Vancouver Wa area who sells on ebay who I believe will do custom cutting. I bought an engine/trans adapter plate from him and the work was nice even though the plate was rather light weight. You might also check to see it there is a trade school in the area with a machine shop class. Last edited by mr48chev; 01-21-2009 at 04:56 PM. |
01-21-2009, 07:04 PM | #5 | |
Gone to greener pastures
Check your local Jr. College.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
01-21-2009, 06:41 PM | #6 |
I will check on ebay and some ag shops around here. I was hoping someone would know of a 4x4 offroad shop that did this kind of stuff locally and at a decent rate.
Will continue to keep digging thanks guys
01-21-2009, 06:54 PM | #7 |
Contact this guy http://www.illusivefabrications.com/ he is on the RangerPowersports forums and does CNC work.
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 http://i195.photobucket.com/albums/z...en58/001-2.jpg |
01-21-2009, 07:21 PM | #8 |
In Springfield Illinois you can sign up at the Capitol Career Center for 75 bucks and then use the shop every Tuesday night for 6 weeks. Try a place like that
01-21-2009, 07:58 PM | #9 |
Why can't you use a cutting torch for that? If you have a steady hand you can get it very close and smooth the edge with a hand grinder.
Dan
Dan Smith Colorado Springs, CO 71 GMC Custom Camper "Longhorn" 454, TH400 73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny "DON'T TREAD ON ME !!!" My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442 |
01-21-2009, 10:47 PM | #10 |
Driving the Thin Blue Line
I'm in St. Charles MO. I would call Allied Motors(It might be called Bessel Motors now). The owner, Ronnie Besselman has an awesome CNC machine in his shop on First Capitol. He can make darn near anything with that machine. And he's a nice guy.
