Old 01-23-2009, 03:40 AM   #1
quickchevy
quickchevy's Avatar
Trailing Arm ?
Has anybody used the trailing arms from ECE or CPP?
quickchevy is offline   Reply With Quote
Old 01-23-2009, 03:53 AM   #2
fine69
fine69's Avatar
Re: Trailing Arm ?
Why would you? The factory ones are awesome.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 01-23-2009, 10:42 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Re: Trailing Arm ?
I'm running a pair of the CPP tubular trailing arms. What would you like to know?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-23-2009, 01:10 PM   #4
bentfab
bentfab's Avatar
Re: Trailing Arm ?
exactly!!!! I'm in the process of modifyng a set for a customer. I'll post pics when there done.
bentfab is offline   Reply With Quote
Old 01-23-2009, 02:55 PM   #5
SCOTI
SCOTI's Avatar
Re: Trailing Arm ?
Please do. What are you modifying?
As for the other responses of "why?", many of the original arms are now @ least 37yrs old & rusted to the point of needing replacement. I can't think of a better reason than that.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-23-2009, 03:22 PM   #6
vin63
vin63's Avatar
Re: Trailing Arm ?
Originally Posted by SCOTI View Post
...As for the other responses of "why?", many of the original arms are now @ least 37yrs old & rusted to the point of needing replacement. I can't think of a better reason than that.
Yes, mine were damaged and rusted beyond repair. I started to make my own out of left-over chromoly tubing. I had booth duty for a company I was doing PR for at the 2005 SEMA show, I ran into Danny Nix and explained my situation - I got one of their first sets of arms from him not long after the show.
Old 01-23-2009, 03:41 PM   #7
bentfab
bentfab's Avatar
Re: Trailing Arm ?
Understand when they are to damaged. I got lucky with this set. I have a sand blaster in my complex so it makes it easy to find out if they are good or bad. I'm keeping the originals because I like the look. When I'm done reinforcing them and adding some custom touch's I'll post the pics. If it works out and you guys like it I'll make it in kit form.
Old 01-23-2009, 06:40 PM   #8
XXL
Seņor Member
XXL's Avatar
Re: Trailing Arm ?
I can think of ONE better... "why not?"
XXL is offline   Reply With Quote
Old 01-23-2009, 06:45 PM   #9
SCOTI
SCOTI's Avatar
Re: Trailing Arm ?
Swapping them because you have to trumps swapping them cuz you want to @ any table . Safety first.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-23-2009, 02:10 PM   #10
XXL
Seņor Member
XXL's Avatar
Re: Trailing Arm ?
Yes.
Old 01-23-2009, 06:48 PM   #11
joe231
joe231's Avatar
Re: Trailing Arm ?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-23-2009, 08:17 PM   #12
Kayotic
Kayotic's Avatar
Re: Trailing Arm ?
I have a set from ECE. What's up? Brand new - only driven 500 feet and still hand tight. Expensive, so make sure you have your mind made up. I decided not to use them or the ECE crossmember...
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 01-23-2009, 08:34 PM   #13
quickchevy
quickchevy's Avatar
Re: Trailing Arm ?
Thinking about doing some i guess mods or you could call it updating.Maybe coil over exc.As far as i know.There is nothing wrong with mine.I will be going down the strip.
Old 01-24-2009, 12:21 PM   #14
rex01atv
Re: Trailing Arm ?
I'm using the round tube trailing arms from CPP and look great! What you need to know is that you will gain some clearance from your frame so you can lower more, but if you are running a rear sway bar you will have to discard it beacause there is no where to hook up the sway bar to the arms? Also if you are planning on installing rear bags you will have to install a bushing in the hole on the bottom because the hole is bigger than the hole in the airbag?
rex01atv is offline   Reply With Quote
Old 01-24-2009, 01:00 PM   #15
Kayotic
Kayotic's Avatar
Re: Trailing Arm ?
About the bolt if you are going to run bags. The ECE arms are the same way. The bolt holes on the arms are 1/2" or so. The thread in the bags (I assume it's typicle) are 3/8".
I re-cut the threads on the bolts that came with my trailing arms. The shoulder is still 1/2" but the threads are now 3/8" unc.
It was nice working in a high performance auto racing facility with a complete machine shop.
ElanMotorSports
Atlanta Craigslist
Old 01-24-2009, 02:47 PM   #16
rex01atv
Re: Trailing Arm ?
Did you use the mounting plate for the bottom air spring to attach between trailing arm?
Old 01-24-2009, 03:25 PM   #17
Shane
Shane's Avatar
Re: Trailing Arm ?
how exactly does the round tube trailing arms provide more frame clearance versus stock
Shane is offline   Reply With Quote
Old 01-24-2009, 03:52 PM   #18
XXL
Seņor Member
XXL's Avatar
Re: Trailing Arm ?
I believe it may just be the nominal difference in effective diameter of the stock 'square' versus the new tubular (I'm guessing maybe 1" or less difference), but due to their contact point being further out on the arc of the arm, that probably translates into a few extra inches.
But... I'm just guessing (like usual ).
Old 01-24-2009, 03:54 PM   #19
Shane
Shane's Avatar
Re: Trailing Arm ?
makes sense ...
Old 01-24-2009, 03:58 PM   #20
XXL
Seņor Member
XXL's Avatar
Re: Trailing Arm ?
makes sense ...
But pics would be better!
Old 01-24-2009, 04:45 PM   #21
Kayotic
Kayotic's Avatar
Re: Trailing Arm ?
rex01atv, on the ECE trailing arm there is a plate welded to the top. The bag just sits on that. It's on their front page Here
Never mind it's hard to see in that pic, with the spring retainer in the way. Mine are all black also.
You know a while back I read a magazine article about the CPP units having a little flex to them. I don't remember the situation i.e drivetrain, if it was racing or towing. Having never seen the CPP in person I heard they are huge, maybe 21/4" dia.
Look out coming through!
My ECE's look much better. It's like 1x3 rectangle tubing with the bend in correct place. Just so much nicer.
Atlanta Craigslist
Old 01-24-2009, 05:03 PM   #22
oldno7
oldno7's Avatar
Re: Trailing Arm ?
OK so I was thinking. You could prob run a 10-11 inch tire with the stock setup, but I'm wanting to run a 17 x 11 rim. So I was thinking of running the trailing arms straight back to the rearend. This would allow you to run bigger rubber out back. You would have to do a few things though. Prob a panhard bar of some sort and modify your wheel wells. You would have to make your own brackets for the trailing arms to bolt to. Prob a coil over shock. Sounds like a lot of work but prob easier than a rearclip. So am I of my rocker or what?
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
Old 01-24-2009, 11:43 PM   #23
SCOTI
SCOTI's Avatar
Re: Trailing Arm ?
No need to relocate the trailing arm mounts to run wider wheels & rubber. In their stock location, you can fit 14" wide wheels w/the correct back spacing. You'll definitely need to widen the wheeltubs & should use an aftermarket Panhard bar (one that attaches to the pass trailing arm from the drivers side).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-30-2009, 09:10 PM   #24
bentfab
bentfab's Avatar
Re: Trailing Arm ?
Here's a few pics of the arms I've been modifying I still have one more thing left (which will add the character to the arm) and also the shock mount once I get them in the chassis. But this will give you an idea of what you can do with just a little clean up and thought.
Old 01-31-2009, 03:14 AM   #25
quickchevy
quickchevy's Avatar
Re: Trailing Arm ?
I am looking at running a 15 by 10 rim with a 3.5 backspacing.the tire will be mt drag radial 325 50 15.Will it fit under the stock wheel well.
