01-24-2009, 04:02 PM | #1 |
Front crossmember...
Our 1971 front crossmember wont bolt into our 1966 Suburban. Its off by an inch. Whats the deal?
1966 C20 Last edited by CanonKid; 01-25-2009 at 02:08 AM. |
01-25-2009, 01:15 AM | #2 |
Re: Front crossmember...
This leaves me to wonder why you would change the whole crossemember when they are the same. Just swap out the control arms and stuff and bolt them on your original.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
01-25-2009, 02:08 AM | #3 |
Well this is what we ended up doing after all. And joe231, yes they were both half ton trucks.
1966 C20 |
01-25-2009, 01:30 AM | #4 |
too wide or too narrow?
are they both half ton trucks?
CHEVY ONLY |
01-25-2009, 02:33 AM | #5 |
which one is too wide?
maybe the sub frame is different than the trucks?
CHEVY ONLY |
01-25-2009, 03:10 AM | #6 |
The frame was to wide.
1966 C20 |
01-26-2009, 01:58 AM | #7 |
60-66 Nut
The frame was probably just a little sprung. Should have been able to just squeeze the frame rails together with something like ratchet straps. The front crossmembers are all the same width whether Pickup, Suburban, Panel, C10, C20 or C30 from 1960 to 1987.....all the same width. Sounds like you got it handled though.
01-26-2009, 11:14 AM | #8 |
One day...
When i did mine i had to use a bottle jack and piece of wood to make it wider but it was only like 1/4 in so i could get the bolts in..
01-26-2009, 05:00 PM | #9 | |
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
