Old 01-24-2009, 08:39 PM   #1
socal
socal's Avatar
Do I need new springs?
the front springs hit on the frame all the time, what can I do to stop that or is it just normal?
Name:  Copy of DSCF0258.jpg
socal is offline   Reply With Quote
Old 01-24-2009, 08:56 PM   #2
jrdv
jrdv's Avatar
Re: Do I need new springs?
My trucks all have a bracket behind the front shackle that prevents it from hitting the frame. Sorry, I don't have a picture.
Your springs look ok to me. They should be replace if they bow upwards. Stock springs are flat.
Also, the bracket is only on the driver side.
john
jrdv is offline   Reply With Quote
Old 01-24-2009, 09:10 PM   #3
socal
socal's Avatar
can someone post a picture of what the back bracket should look like?
Old 01-24-2009, 09:23 PM   #4
socal
socal's Avatar
Here is a picture of the whole leaf spring
Name:  Copy of DSCF0259.jpg
Old 01-24-2009, 11:42 PM   #5
NEVERENOUGH
NEVERENOUGH's Avatar
I think that this a a common problem. Offroad desing sells a shackle that is not much longer than stock but a lot more heavy duty that should help with the problem. One other thing to think about. Did you buy the springs or were they on the truck. You might want to check the part number they might be for a 73-87 truck instead of 67-72. The springs for the 73-87 are longer this could casue your problem.
NEVERENOUGH is offline   Reply With Quote
Old 01-25-2009, 12:19 AM   #6
maximum destruction
In House Collision Technician
x2. when i put my new 12 in. springs in my 86 1 ton, they actually pulled the shackle to the front, almost to the same angle as u have here.
MAXIMUM DESTRUCTION
maximum destruction is offline   Reply With Quote
Old 01-25-2009, 09:47 PM   #7
socal
socal's Avatar
I was watching a show on tv of a muscle car built up and they were slightly towars the front but this was a car. Pictures would help me alot guys...
Old 01-26-2009, 01:27 PM   #8
b454rat
Guess I can't see it, but where is it hitting the frame?? You want the shackle angled back alittle bit, it helps in flexing and a better ride. I would get longer shackles, only need 1/2-1" tops. Can go to a metal shop and get some peices probly for free, just cut them to length and drill a 7/16" hole.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 01-26-2009, 03:42 PM   #9
socal
socal's Avatar
Its hitting on the red, I bought the truck with the lift already. Could it be the shocks?
Old 01-26-2009, 05:30 PM   #10
Yukon Jack
Yukon Jack's Avatar
No. You don't want the shocks to be the limiting the spring movement or you'll break your shocks. Your springs must be flexing a good amount to be having contact where you have indicated. I would consider your shackle angle to be fine.
Hopefully the guys who know a bit more than I about suspensions will have a good recomendation for you. Slightly longer shackles will probably be the recommendation.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-26-2009, 06:41 PM   #11
worley91
Big Boys With Big Toys
Wrong springs or longer shackles
worley91 is offline   Reply With Quote
