Old 01-26-2009, 04:12 AM   #1
greygoose
greygoose's Avatar
Distributor ?
I need a distributor for my 71 c10 307 and I'm looking to cut corners every way that I can.So I'll be getting it from the junk yard,but I need help,I want to make it hei or get a hei from a yard.What should I be looking for and getting so it will bolt up and wire up and what all does the process entitle ....Thanks
If it ain't a chevy,I don't want it
greygoose is offline   Reply With Quote
Old 01-26-2009, 07:41 AM   #2
lax54650
Re: Distributor ?
i was just on ebay there is a new aluminum 50k hei with cap rotor and coil including warantee for $35 i think it would be hard to find a good yard one and put new cap rotor and coil in for that much cash. skip white has a 60k for less than 50. that is what i will put in when i get to that point.
lax54650 is offline   Reply With Quote
Old 01-26-2009, 09:39 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Re: Distributor ?
This is the best site I've found when looking to convert or rebuild an HEI. He includes part numbers and some good info towards the bottom of the page.
He is converting a 350 but it should apply to your engine.
http://rmcavoy.freeshell.org/HEI.html
68gmsee is offline   Reply With Quote
Old 01-26-2009, 10:10 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Distributor ?
Add this site to the one above and you will be covered.
http://www.rustpuppy.org/ignition2/Ignition%202b.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-26-2009, 01:09 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Re: Distributor ?
Good site. Thanx.
Old 01-26-2009, 11:59 AM   #6
Sinister
Between Trucks...
Sinister's Avatar
Re: Distributor ?
Here's the one I got off of E-bay: http://cgi.ebay.com/ebaymotors/CHEVY...mZ220323570866
$60, free shipping, 4 year warranty. The Skip White one's work out about the same with shipping and a 3 year warranty.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
