Old 01-26-2009, 10:09 PM   #1
tylerg.
4wd to 2wd conversion
I know it can be done, but how do you convert a 4wd truck to 2wd?
Is there a kit you can buy? Where? How much?
and by the way how many gallons does the stock gas tank on a 87' c-10 hold?
tylerg. is offline   Reply With Quote
Old 01-26-2009, 11:06 PM   #2
1984 swb chevy
1984 swb chevy's Avatar
Re: 4wd to 2wd conversion
i think you should find a 2wd frame and swap your parts over. I'm not sure if anyone makes a kit to do the swap. I did 2wd to 4wd years ago and just switched frames.
2010 Tahoe
1984 C10
2005 Harley FLH
1941 Willys Pickup (will never get it done) not for sale
1984 swb chevy is offline   Reply With Quote
Old 01-26-2009, 11:19 PM   #3
CrashOverKill
I have read a feww blogs on going from 2wd to 4wd so I would imagine it is the reverse LOL I plan on converting my 1 ton dually from 2wd to 4wd to bad you dont live closer we could just swap parts LOL.
CrashOverKill is offline   Reply With Quote
Old 01-27-2009, 12:19 AM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
This thread will help...
http://67-72chevytrucks.com/vboard/s...d.php?t=168231
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-27-2009, 08:54 AM   #5
softballnrd27
Always a work in progress
softballnrd27's Avatar
You will need all the rear hangers. The shackle end, the leaf spring end, and the bump stops(unless you are lowering it). You will also need the whole front sub-frame wth the suspension and motor mounts that go from the frame to the x-member. also there is a x-member in front of the suspension x-member that you will need to get as well that holds the brake proportioning block. I just got all of the brackets for the rear yesterday from the pull-a-part for $28. You can also get the longer 2wd springs(some came with 56" vs the 52" on the 4wd) if you want a smoother ride. A cordless sawzall will be ur friend if you get parts from the pul-a-parts.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
