01-27-2009, 10:25 PM | #1 |
Fans - clutch vs. fixed?
My truck has a 5 blade clutched fan..
How do I know if the clutch is good/bad? What about going to a fixed fan (clutchless)? Thanks...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-27-2009, 10:51 PM | #2 |
Re: Fans - clutch vs. fixed?
If the thermal clutch is good, you can hear the fan kick on and off when the eng is hot. You should also feel the difference in airflow.
If you have a non-thermal clutch, then I'm not sure, I've never troubleshot one. The thermal type will have fins all over it and a coil facing toward the radiator.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-27-2009, 10:56 PM | #3 |
Off topic, Mike why not just switch to an electric fan? in the hot florida sun all my vehicles I always have switched to electric fans they cool so much better.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
01-28-2009, 10:59 AM | #4 |
mike i have a fixed fan that i got off of a suburban , and i have no cooling issues even with an old rad. if the clutch on the fan is leaking a greasy-like fluid, it needs to be replaced. the purpose of a fan clutch from my understanding is to engage/dis-engage the spinning of the fan when it is needed or not needed. at start-up and highway, the clutch is not engaged and the fan will not spin as much, i supose to free up some of the stress that the motor uses to spin the fan, freeing up more hp i suppose. the thermostatic coil on the outside of the clutch moves the clutch fluid on the inside to make the fan spin or slow down.
okay, i just found this, this should help. http://en.wikipedia.org/wiki/Fan_clutch also if that bi-metal coil is broken or missing, you should replace
'55 3100 2nd series short-bed stepside '70 Corvette coupe stingray '71 Chevelle 2-dr coupe SS clone '71 C10 long-bed fleetside '83 long-haired brunette wife |
01-28-2009, 11:18 AM | #5 |
The trouble with most fixed blade fans is that they usually sound like a jet taking off,,,,all the time. My 67 had a 6 blade ,flex fan. MAN,,you talk about loud !!-KB
01-28-2009, 11:21 AM | #6 |
Between Trucks...
I've got a nylon flex fan, quiet and keeps my 350 at 190*
Beat it to fit, Paint it to match... |
01-28-2009, 11:40 AM | #7 |
be careful if you are shopping for used original fans, i have heard many stories of fan blades going through hoods because the rivets were compromised in some way. i.e. some rivets were missing, cracked blades, etc.
01-28-2009, 04:52 PM | #8 |
I have heard that about the flew fans... My original fan is a little rusty but seems to spin ok... It does have a slight amount of oil on the shaft but nothing bad for a 40 year old fan...
My hesitation in going with the fixed fan is a slight loss of power and the constant noise. If I see that my clutch fan isn't cooling enough then i'll just replace the clutch... thanks for the tips guys...
