01-29-2009, 12:21 AM | #1 |
Ride tech tubular lowers and a sway bar
I bought my tubular lowers a year ago and am now looking for a swaybar. The musclebar swaybar from ride tech is $400.00. Well I cant do that and I've found this one http://store.summitracing.com/partde...5&autoview=sku in another members post for $180 something shipped. Problem is its 40.5" center to center (hole to hole) and the mounting holes for the ride tech lowers are about 47". I can either cut the tabs off the tubular lowers (powder coated) and re weld or possibly re bend the swaybar to make work. Any suggestions other than buy the musclebar?
01-29-2009, 11:44 AM | #2 |
A guy with a truck
Re: Ride tech tubular lowers and a sway bar
Nathan Porter from Porterbuilt Streetrods told me that he can have a custom bar bent for less money than that one from Summit. I think they were from Hellwig? I would give him a call and see if he can help you out.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 01-29-2009 at 11:44 AM. |
01-29-2009, 01:15 PM | #3 | |
It's Better With Nitro
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 01-29-2009 at 01:16 PM. |
01-29-2009, 01:25 PM | #4 | |
josh |
01-29-2009, 04:16 PM | #5 | |
01-29-2009, 09:07 PM | #6 |
Bodydropped71
Are you planing on getting really low? Like laying frame? I had those arms and mine being z'd those arms were way to close to the ground.
01-31-2009, 06:27 PM | #7 |
No just bags, no cups and 2.5" dropped spindles. Its close but not that low.
02-01-2009, 01:37 AM | #8 |
I can get you a 1.125" bar for $200 shipped. If you have the "new" style ART lowers (the ones that have the shock mounting tab pointing up) it will fit like a glove.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! Last edited by PBFAB.COM; 02-04-2009 at 02:58 PM. |
02-04-2009, 06:12 PM | #9 |
67-72 parts collector,…
I will be in touch,...
