01-31-2009, 11:30 PM | #1 |
People know me
wood floor replacement
Well I have a 67 long wide box that i am in the process of building, the original wood floor is rotted away and the po threw a piece of plywood back there, I plan on replacing this myself and have a few questions
First what is the most common wood to use as replacement? I am not wanting to spend a fortune doing this $150-200
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
02-01-2009, 12:32 AM | #2 |
Re: wood floor replacement
Oak is what is most commonly used as far as I know and the wood kits are more like $300-$400.Wood only.
02-01-2009, 12:36 AM | #3 |
Unless you are a woodworker, that's just not possible. Along with tghe kit you'll need the runners and bolt kit as well. Then you'll need to finish the wood. Expect to pay around $450-500.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
02-01-2009, 12:38 AM | #4 |
Or I have a wood only kit I will sell you supper cheap.
00' Z28 ("wifes" car) 92' Mustang w/sbc everything needs a little heart beat 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it |
02-01-2009, 03:27 AM | #5 |
People know me
I am totally capable of making a replacement bedfloor, Just wanting to know what are the most common material, so is oak the only thing? what came factory? I have a few buddies that work at the lumber yard, so i can get there price on material, all my strips look to be in good shape, so after media blasting and paint those will be put back into service, I was already planning on replacing bolts, and have a family friend that owns a fastener shop here in town that sells to me at cost.
02-01-2009, 10:09 AM | #6 |
Cool. I am a woodworker [decks/pergolas/furniture/cabinetry, etc] so I can help with just about any stage of the project you have questions about.
Among the Oak varieties, your best bet is White Oak due to it's longevity outside in the elements. Most people have red oak kits and while it's a hearty wood it's really not that great for outside use. There are many exotics which would be better than oak but they get awful pricy. As far as finishes go you'll need something with UV protection such as spar urethane varnish [Minwax] or a boat deck varnish. Multiple coats are suggestion for more protection. Last time I did a bedwood project, it was for a 1929 Model A. The white wood was milled to 13/16" and then cut to match the floor pettern. I used Boiled Linseed Oil to pop the grain, then coated with 7 coats of spar urethane. Looked great. Good luck with the project and post some pics when you're done!
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 02-01-2009 at 10:09 AM. |
02-01-2009, 01:46 PM | #7 | |
Spanked once
The ole 350 budget build. |
02-01-2009, 02:38 PM | #8 |
The Hammer Man
i am close enough i think, but is the hardware kit readily available online? how much for the wood? where in indiana?
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T |
02-01-2009, 03:10 PM | #9 |
Southern yellow pine was the factory choice, pretty rot resistant. White pine boards won't last very long. Red oak looks great but not real weather resistant. White oak is used in many grain truck and some semi trailer floors, hard and rot resistant. Our next project will likely use the southern yellow pine, more of a driver than a show truck.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
02-01-2009, 01:23 PM | #10 |
Thanks. I used the same clear polyurethane for the top and bottom of the boards. I think about five coats each.
02-01-2009, 01:46 PM | #11 |
JUst wanted to say that looks really good!!!!!
1968 GMC Rebuilding Stage 2001 Camaro SS SOLD |
02-01-2009, 03:16 PM | #12 |
02-01-2009, 01:39 PM | #13 |
there is a wood called purple heart semi trailer manufacturers use it on there decks cause it can withstand massive abuse very hard wood, and its kinda purple! check with some manufacturers they may have some waste.
02-02-2009, 12:24 AM | #14 |
i bought my wood and hardware off ebay.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
02-02-2009, 10:16 AM | #15 |
Wrench Wench
I don't mean to hijack this thread, but does anyone have templates for the replacement boards? length-width-depth-hole spacing and size-groove depth for strips-etc. I have every kind of wood working machine, I just need the measurements.
If everyone had good taste, who would buy all the FORDS? Women join us!! BUSTED KNUCKLE BABES "Face it girls, I'm older and have better insurance" -Fried green tomatoes |
02-02-2009, 11:24 AM | #16 |
BOHICA
The type of wood you use depends on your needs. If your not going to leave it out in the rain, about any kind of wood will do as long as you protect it from the sun. If you want factory go with the pine, if you want custom, I would go with the purple heart, it looks awsome with a little clear on it.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
02-02-2009, 11:37 AM | #17 | |
http://www.gmcpauls.com/47-72_BedWood_Info.htm |
02-02-2009, 07:14 PM | #18 |
Wrench Wench
Thanks kyull67, thats a good start for me.
