02-02-2009, 07:54 AM | #1 |
wheels and tires
will 17X10 51/2 backspace with p27540zr17 fit on 84 sub without problems
02-02-2009, 08:29 AM | #2 |
Re: wheels and tires
need some input guys he wants 500 they wont last long
02-02-2009, 11:27 AM | #3 |
Should fit just fine. With a 10", you need a minimum of 4.5" backspace to clear the fender lip. 5.5" backspace will work even better. I don't know what the maximum backspace you can run before it starts contacting the inside fenderwell or suspension, though.
If worse comes to worse, you can run a .5" spacer to push the wheels out, but I don't think you'll have an issue at all. If I recall, lots of guys here on the site have 20x9.5 wheels with 5.5 backspace. |
02-03-2009, 12:41 AM | #4 |
They'll fit but that's a short tire for these trucks.
