02-02-2009, 12:06 PM | #1 |
BOHICA
spindle/brake question
Is there any difference between a 68 and a 72 spindle? Specifically is there any reason you couldn't put 72 disks on a 68 spindle? I see a lot of people swapping out the whole front end to put disks on the older models. I thought of doing this as well, but I would be replacing the rotors/calipers/lines anyway. Why go through the hassle of changing out a big part only to disassemble it and replace all the components. Also, does anyone make 5-lug front drums for a 68? The PO put all new brakes on it right before I bought it, but I would like to put 5-lug wheels on it. I don't really need disks right now, but I'm kicking around all possibilities.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
02-02-2009, 12:17 PM | #2 | |
Son of a gun
Re: spindle/brake question
Bill BEATERS ARE NEATER Last edited by Bus Ted Knuckle; 02-02-2009 at 12:19 PM. |
02-02-2009, 12:39 PM | #3 |
I would like to add...
If you trim the steering stop off the spindle for use on stock '68 a-arms, could these spindles still be used later on an aftermarket spindle? |
02-02-2009, 12:45 PM | #4 |
67-72 parts collector,…
[QUOTE=Kayotic;3121093]I would like to add...
If you trim the steering stop off the spindle for use on stock '68 a-arms, could these spindles still be used later on an aftermarket spindle?[/QUOTE] I don't understand this statement. Alot of people use the '73+ parts because they are cheaper and readily available at most parts store instead of the 2 year only 71-72 parts. And NO,... you can't put a '72 disc on a '68 spindle.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-02-2009 at 12:47 PM. |
02-02-2009, 03:53 PM | #5 |
BOHICA
thanks for the info, how about the 5-lug front drums for the 68? Any vendors here carry such a thing?
02-02-2009, 05:46 PM | #6 |
I wish I was a cowboy
Good luck...I don't think I've seen that. You can get 6 lug rotor/spindle setup that will fit your factory 68 a-arms/ball joints, I think...
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
02-02-2009, 05:56 PM | #7 |
BOHICA
Yeah, I've seen that. I was thinking maybe someone around here had heard of a 5 lug drum off of a full size car, or a place to find a new one
02-02-2009, 09:26 PM | #8 |
Oops!
I am sure the comment above was ment to be '72 not '92. |
02-02-2009, 09:29 PM | #9 |
