Old 02-02-2009, 11:10 PM   #1
1970GMC468
1970GMC468's Avatar
Fgb52 kit
Grendel is the man! I love this kit! My question is: What lift do you get with different lift rear springs? Im looking at a close to six inch or a four, I have not decided yet...
1970GMC468 is offline   Reply With Quote
Old 02-03-2009, 09:23 AM   #2
drbyrdman
drbyrdman's Avatar
Re: Fgb52 kit
Iam doing the b52 swap up front right know. and using Blazer rear springs. I might have one side done tonight. ill let you know how much lift i get. should be around 4".
drbyrdman is offline   Reply With Quote
Old 02-03-2009, 10:59 AM   #3
FormerMember
Re: Fgb52 kit
With stock 3/4t springs, I get 5".
With stock Blazer springs, I get 4"
FormerMember is offline   Reply With Quote
Old 02-03-2009, 11:25 AM   #4
1970GMC468
1970GMC468's Avatar
Re: Fgb52 kit
Sweet I have some 3/4 ton springs! Thanks again guys for the help! I bought the kit last night. When I get started I will let you all know how its going with pics and such... By the way, what will I do for my engine crossmember? I dont think I can leave the breast bone in there? I have a 73 4x4 frame, will that cross member work? The truck is a stock BBC truck with a 468 now (originally a 396).
Old 02-05-2009, 09:27 AM   #5
drbyrdman
drbyrdman's Avatar
Re: Fgb52 kit
I got the front installed. it did lift it aleast 5 inches. but i do not have the engine or tranny in so dont now how much i will get. tell you one thing it sure is flexy!!! going to have to run dual shocks for sure and some big bump stops.
Old 02-05-2009, 09:54 AM   #6
FormerMember
Re: Fgb52 kit
Which springs did you use?
Shouldn't need double shocks, unless you want to run them. I did a sway bar on the K5.
Old 02-06-2009, 07:59 PM   #7
drbyrdman
drbyrdman's Avatar
Re: Fgb52 kit
pics for you
Old 02-13-2009, 12:02 AM   #8
og350
og350's Avatar
Re: Fgb52 kit
ok so i am going to do this swap on my 71 and right now it has stock length springs but are 6" lifted. so i want to stay with the 6"s of lift so what 52" spring should i look for?
og350 is offline   Reply With Quote
Old 02-13-2009, 09:36 AM   #9
drbyrdman
drbyrdman's Avatar
Re: Fgb52 kit
the b52 is a 4" lift. so i would get some 2" lift rear Blazer springs. or just get some juckyard springs like i did and add a couple leafs to get the height right. you need to make sure you have the spring wraped at both ends or there going to move when you turn the steering wheel.
Old 02-13-2009, 12:33 AM   #10
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: Fgb52 kit
drbyrdman,
You gonna put some degreed shims in to fix your pinion angle?
Joey~AP is offline   Reply With Quote
Old 02-13-2009, 09:34 AM   #11
drbyrdman
drbyrdman's Avatar
Re: Fgb52 kit
Originally Posted by Joey~AP View Post
drbyrdman,
yes, iam need to get the engine in and some weight in the rear and use my angle finder and do it. i want to do it right the first time.
Old 02-13-2009, 09:50 AM   #12
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Fgb52 kit
that is one good looking truck =-)
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
