![]() Join Date: Jan 2005
Drilling through carpet
What is the best way to drill small holes through carpet without snagging the carpet??
Re: Drilling through carpet
I've always took a sharp razor blade and cut a small 'x' into the carpet where the bolt will come up through. I don't think you want to run a drill bit through the carpet. That could cause some problems.
New Member
ditto!!
![]() Join Date: Jan 2008
Sodering iron works great for me!
Oops, Soldering
![]() Join Date: Dec 2008
What are you trying to do ? I would not "drill" carpet...if you are putting holes in the metal below, take the carpet out / pull it back...If you are trying to put holes in the carpet for wiring or something, I always get a large nail red hot and poke it through, that way it keeps it from un raveling around the hole.
^yeah I've found that burning a hole with a rod or nail works really well, unless it's somewhere noticable.
I just put new carpet in my truck and had to drill holes for the the screws for the new door sill plates - I put masking tape over the carpet and drilled through the carpet with a sharp 3/16 bit and didn't have any problems snagging the new carpet.
I need to drill small holes for the Lokar shifter boot cover and the door sill covers. The problem is I can't pull the carpet back around the shifter since it's already mounted. So I might try to use a soldering iron point to burn holes or something. I had heard if you reverse the drill that it might wear a hole with out snagging the carpet. Just looking for some good ideas.
#10 | |
Masking tape might just work...I might try that
Sisyphus was my mentor!
![]() Join Date: Sep 2002
You can also cut the "x" in the carpet & place a piece of tubing into the x thats bigger than the hole to be drilled. Drill down through the space created by the tubing. Remove tubing & voila.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
i've always used hole punches// available at hardeware stores sears cfart stores and online thru leathercraft suppliers
i've always used hole punches to make holes in carpet// available at hardeware stores sears cfart stores and online thru leathercraft suppliers
#15 |
![]() Join Date: Jul 2004
Pencil tip soldering iron works great for me, stinks like H**L, but gets the job done fast.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#16 |
drill in reverse for a bit and then drill through. shouldn't snag.
#17 |
![]() Join Date: Dec 2002
Several years ago, I had to install plug in receptcales on a carpeted wall. ( The carpet extended about 4 feet from the floow with a molding on top of carpet/wall.) Used a pencil tip soldering iron; worked great to 'burn' in the mounting holes...Worked great !!
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
#18 |
![]() Join Date: Feb 2000
Another option is to take a small piece of tubing and sharpen the tip. Chuck it in the drill and use it to drill thru the carpet.
But I like the idea of the hot soldering iron to burn a small hole. |
