Old 02-06-2009, 12:52 PM   #1
b&a72
Active Member
b&a72's Avatar
Serpentine Belt Systems
Does anybody know what year motors we can pull serpentine brackets off of that will fit our trucks? I know there was a thread somewhere but I can't find it.
b&a72 is offline   Reply With Quote
Old 02-06-2009, 01:11 PM   #2
brian mac
Re: Serpentine Belt Systems
The serpentine systems I am familiar with are for the small block engine. I think GM began in 1988 using them in trucks 1/2 & 3/4 ton. These have the a/c compressor on the passenger side (r-4 style) and the alternator on the driver side. In 1996 the vortec series engine changed the compressor to the driver side and used the sanden style compressor. I think all of these had a smog pump but a bypass pulley is available. I have no idea what Gm cars used this same setup. I would guess caprice, camaro, firebird. I do not think the GENERAL has used a V-belt since 88. Maybe this helped! Also you must have cylinder heads with accessory bolt holes in the ends.
brian mac is offline   Reply With Quote
Old 02-06-2009, 01:22 PM   #3
wHATANERD
wHATANERD's Avatar
I bought this on out of a junk yard from a 97 Chevy.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 02-06-2009, 01:35 PM   #4
b&a72
Active Member
b&a72's Avatar
whatanerd does that not have the power steering bracket on there?
Old 02-06-2009, 02:00 PM   #5
wHATANERD
wHATANERD's Avatar
Yes, I edited the phot so maybe it can be seen better, The Power Steering Pump is mounted to the big Aluminum bracket, and by the bracket that attached behind the altenator (Red arrow). This bracket also mounts to the exaust bolts (yellow arrows), however I cannot bolt them in until I figure out how to modify for headers as the flange is alot shallower.
Old 02-06-2009, 02:01 PM   #6
wHATANERD
wHATANERD's Avatar
Sorry, I forgot to ad the photo
Old 02-06-2009, 02:05 PM   #7
wHATANERD
wHATANERD's Avatar
There is also another bracket that goes behind the tentioner to one of the intake bolts that needs to be modified before I can install it due to the Vortec heads having a different bolt pattern.
Old 02-06-2009, 02:08 PM   #8
b&a72
Active Member
b&a72's Avatar
I see it now, that is the problem I am going to run into is the header mounting. The backet sits over the top of the manifold/header correct?
Old 02-06-2009, 02:13 PM   #9
b&a72
Active Member
b&a72's Avatar
I am not running vortec heads so would I have the same issues as you?
Old 02-06-2009, 02:43 PM   #10
wHATANERD
wHATANERD's Avatar
It's not really a problem, it just takes a little fab. work. Attached is a photo of a friend 94 Chevy that has been modified to work with headers.
Old 02-06-2009, 02:44 PM   #11
wHATANERD
wHATANERD's Avatar
The upper brace should be fine, be If your running header the lower brace will still need to be modified.
Old 02-06-2009, 03:41 PM   #12
b&a72
Active Member
b&a72's Avatar
lokks easy enough thanks for the help!
Old 02-06-2009, 04:47 PM   #13
wHATANERD
wHATANERD's Avatar
anytime
