![]() Join Date: Feb 2008
One more Auto Meter Gauge question - VOLTS METER
Ok, I got everything hooked up.....but I got ONE more question! (ok I might have more but Im hoping this will be my last)
My gauges have a POSITIVE LEAD, a GROUND, and a SENDER.. I have the positive all linked together with the power from the rest of the gauges, I have the ground the same way..... and then I noticed I didnt have anything to the sender BUT I was getting a VOLTS reading... ????????????????????????????????? How is that possible? Shouldnt I have to put the wire that I have going to the battery to the sender to get a VOLTS reading?? ????????????????????????????????? THANKS!! |
Never Ending Projects
Re: One more Auto Meter Gauge question - VOLTS METER
That's how they normally worked. I was surprised when you said you had a sender connection as well. My guess is it's one style housing but the sender lead doesn't do anything.
I would not put anything on it. If you think how a volt meter works, it only needs 12+ and a ground. I assume you got your fuel gauge working?
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Yes, THANK YOU!!
I said the hell with tan wires and went straight for that wire that plugs into front of fuze panel. I took that wire went straight up to SENDER and it worked! THANKS AGAIN!! Im going to hook a charger/tester up to the battery and test the Alternator, if Im getting a good read out....Ill leave it alone! I cant wait to drive it!! |
Great!!! Post up some pictures once you get it out on the road.
Glad I was able to help.
