![]() Join Date: Oct 2008
HELP! Wheels hitting calipers
OK, so I just did my six lug disc brake conversion today on ECE drop spindles on my 70 stepper. I went and mounted my wheels and they won't turn! So I take them back off and sure enough, it's the caliper hitting the wheel. These are stock steel wheels, not aftermarket. I can get them to clear w/ a 1/4" wheel spacer, but WTF? Has anyone else have this problem and what did you do to correct it? I didn't really want to buy new wheels, I'd rather keep my stock steelies for the old school look
Re: HELP! Wheels hitting calipers
Your going to need the 71-86 or 87 (can't remember which year they changed) six lug steel wheels, they have a deeper offset than the older wheels to clear the calipers.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
Do a search here, theres been lots of posts about grinding the calipers for clearance. Many 4x4 builders grind the calipers for 15" wheel clearance.
![]() Join Date: Jan 2001
4x4 71-72 blazer wheels should work but i think it will bump out your tire 3/4 of an inch on each side.
i have a set for sale if you need em . zip is 08527 there somewhere on the parts board . if wanna go that route ill send you a link (edit) heres the link http://67-72chevytrucks.com/vboard/s...d.php?t=317824
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) Last edited by jc; 02-07-2009 at 11:15 PM. |
Careful with that caliper grinding to clear the old wheels, it may not be that great of an idea to grind on something that is so critical to stopping your truck. When Disc bakes became available in 71 GM didn't just grind the calipers to make them fit, they redesigned the wheels to clear the calipers. There are lots of 71 and up 1/2 ton 6 lug 4x4 wheels out there.
Just something to think about. Jeff
later wheels is the answer the early wheels both 5 and 6 lugs are cars and trucks have different construction and dont clear disc brakes// grinding calipers IMO BAD IDEA
Old member
Do it right and do it safely for you, your family and my family please. Buy new wheels.
As stated above Chevy didn't grind the caliper's for the 71,72 models. I know buying more wheels wasn't in the plan but it's the right thing to do. Spacers are better than grinding but the wheels would be the answer. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Formerly- 1972SuperCheyenne
Throw some six lug ralleys on there, they look cool and still give it the old school look.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
The early wheels are for drum brakes, which have a different shape on the inside of the wheel than disk brake wheels. You'll have to use later wheels(71+) or aftermarket.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub Last edited by sick69; 02-08-2009 at 01:13 PM. |
Guys thanks for all your input. I can assure you that I won’t do anything to jeopardize mine or my family’s safety. I have two girls that both love hotrods. I want them to have fond memories of the truck in there childhood just like I have.
Posted via Mobile Device |
Old member
The right wheels, '71-'91 4wd, will do the trick. But on grinding rotors, I know to fit 15" wheels on a 3/4t truck all you do is grind the casting ridge which is excess material. The radiused area that conforms to the wheel 'peaks' at that ridge and you just flatten it out some. Still more material in that area than the rest of the caliper. I did this years ago with no adverse affect what so ever.
![]() Join Date: Aug 2019
X2 for special K, In the past I have ground Calipers. Your not grinding the back side were the piston is. Your grinding the top front(outside) and only grinding a little. We had to do it when I worked in Experimental @ GM. We didn't have any new wheels to use yet. But for the look of a restored truck I would buy new wheels.
