resto body guy
fuel injection question
i'm installing my 87 tbi 350 motor and 700trans in my 71super cheyenne truck well i want to know if the fuel sender from the 87 chevy truck will work with the 71c-10 gas gauge?? i'm planning to install a new full size blazer tank so the sender should work. i just need to know if i need something else??
any tips are welcome.. |
resident oilfield trash
Re: fuel injection question
i think it should we just put a sender from a 91 sub in an 81 pickup
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Hook an ohmmeter between the center terminal on the 87 sender and the mounting flange and if it reads 0-90 ohms as you move the arm full down to full up then it should work.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#4 | |
Old member
I'm using a 93 suburban tank and sender in my 71 and it's hooked to the factory gauge.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Active Member
What modifications where done to make an 88 fuel tank fit? That would make fuel injection a breeze!!
1971 SWB SOLD
I am using a Blazer 31 gallon tnak and used the crossmemers out of the 88. It fits great but might not work in a shortbed as it is in a longbed now.
