Old 02-12-2009, 03:36 PM   #1
Blazer Dude
Blazer Dude's Avatar
Spring questions
I have a 70 blazer that is not lifted and has 32 1/2 inch tires on it. The thing that i dont like is that it hangs a little in the back and i was wondering if you can just add a leaf? And if i do will i have to lengthen my drive shaft?
Blazer Dude is offline   Reply With Quote
Old 02-12-2009, 03:42 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Spring questions
With or with out the top on? (I will assume on?) This is a very
common problem with Blazer/Jimmys. I have never tried to add
a leaf but I am pretty sure that would solve it. Mine had a 4/6
lift and that cured the problem. Another option is a 1" block
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-12-2009, 06:24 PM   #3
Critter
Future TOTM Winner
Critter's Avatar
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 02-13-2009, 12:32 AM   #4
Blazer Dude
thanks for the answers i checked out the ez inch that is prob the way i will go. That seems like a good way to go. plus it wont make it ride worse than it already does
Old 02-12-2009, 03:51 PM   #5
70 Suburban
Rods
What does your front spring look like. There was an hd option for blazers front end. Makes the back look like its taking a dump.
70 Suburban is offline   Reply With Quote
Old 02-12-2009, 04:44 PM   #6
chalet2506
get an ez inch from diy4x.com or zero rate from offroaddesign.com. You shouldn't have to mess with your driveline.
chalet2506 is offline   Reply With Quote
