Rochester Quadrajet
So while poking around my truck I've now found I have a TH350 not a TH400 as PO normally said AND to really top it off.. I pulled the serial # off my carb.. some funny results..
The number I got was: 1708-5-5-8-6 Which basically means: 1708 = 1980 5 = 1985 5 = Cali Emissions 8 = Checker and Marine 6 = Auto transmission Upon doing some reading it appears Checker and Marine is exactly that a marine company so it perhaps looks like my Qudrajet belongs on a boat ... |
The One And Only !!!
Re: Rochester Quadrajet
If you think about it, It is on a boat.... ![]() If it performs properly I wouldn't worry about it....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
#3 | |
![]() Thing is its not working properly.. if I put the pedal to the floor it bogs badly and looking at it today looks like there maybe a gasket leak (just not a lot). So I'm going to do as said and buy a 600 cfm carb and pull it and use it as a backup means or sell it to someone for parts. |
You could tie a rope to it and use it as a "boat" anchor ! ![]() Sorry..... Good Luck with the new carb.....
