02-16-2009, 08:21 PM | #1 |
the beast roars but needs carb help
I finally got the 454 fired up Valentine's Day (wife was sick, play day for me!)
Problem - it runs/revs fine once started, but won't start on its own without gas being poured in the carb - 1407 Edelbrock, manual choke (cable not hooked up yet); bought carb reconditioned, online from a stranger last year. I'm no carb expert, but I should be able to see/hear gas pumping in the carb when I crank the throttle linkage, right? Your thoughts welcome. |
02-16-2009, 09:33 PM | #2 |
Re: the beast roars but needs carb help
It looks like you have a see through gas line filter..should be able to tell if the fuel pump is working by observing the filter. Another thought..carb floats set to specs?
Bob |
02-16-2009, 10:56 PM | #3 |
Resistance is Futile
I had this same issue steverino66.....I hate to tell you, but its probably in the tank. Your getting air in there somewhere. My 'burb did the same thing and I finally found a cobbled up sender in the tank. It had silicon on it and was leaking. I replaced all the lines and pump, didnt fix it. Found a rubber'jumper' piece on the frame...replaced hose, didnt fix it. Finally the tank and it works now. If it sits for awhile I have to crank it 3x's and it fires 3rd time every time.
Start tracing your fuel lines.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
02-16-2009, 11:56 PM | #4 | |
I may be down to yanking the carb and finding a local expert unless somebody has a better suggestion - as mentioned, I'm no carburetor guy. |
02-17-2009, 01:38 AM | #5 |
Check that banjo bolt setup at the fuel inlet. I had issues with one of these carbs awhile ago. You can take that top off and look into the fuel bowls see if theres junk.....use carb cleaner with a squirt tube and you can shoot thru most passages.
Im not a carb expert by any stretch, either.
02-17-2009, 01:51 AM | #6 |
60-66 Nut
Sounds to me like a malfunction with the accelerator pump. When you open the throttle. do you see gas squirting into the venturies?
02-18-2009, 04:40 PM | #7 |
chrome makes it go FASTER!
Here is a schematic and owner's manual for your carb.
Follow the troubleshooting guide page 22-23 to cure most common problems. http://www.scribd.com/doc/2537789/carb-owners-manual
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
02-18-2009, 06:15 PM | #8 | |
Thanks! |
02-18-2009, 06:28 PM | #9 |
Any update? Im curious and trying to learn. As I mentioned above, I had issues with an EdelB that wouldnt idle. I messed with it for 3 days and never got it working. It would start, rev all day, and NEVER idle. I ended up even taking the metering rods completely out so gas should've poured in it and it would not idle.
02-18-2009, 07:10 PM | #10 | |
Nothing yet - will be at least Sunday before more play time (on my dinner break right now - covered up with work). Check out the link Retodd sent above to the manual - looks very helpful. |
02-23-2009, 04:45 PM | #11 | |
Thanks to everyone who replied. |
02-23-2009, 06:38 PM | #12 |
Ive made that adjustment before; I thought it just applied the accelerator pump earlier. Im going to have to check out my 'bad' EdelB.
