Cutting holes in X member?
I am going to be installing some rings in the rear x member for exhaust to go through BUT I don't have a plasma,oxy torch. Is there another way? I know I could use a hole saw but I would have to find a way to center it any other ideas.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
Re: Cutting holes in X member?
Hole saw through a 2 x 4 the size you want then screw or clamp it to the crossmember. This will keep the hole saw steady when you go through the crossmember without having to have a pilot hole in the center.
Do your hole saws not have a pilot bit to keep them centered?
If you can find it cheaper, I can fix it! |
#4 | |
Good idea on the use of wood as your 'pilot' hole.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-17-2009 at 11:16 PM. |
i used an air body saw for mine. it took a little time but was worth it since there was zero cleanup after and no heat involved.
I never thought about the 2x4,HUH my dads a carpenter too... DUH. Thanks. I'll get some pics of the process this weekend.
Resistance is Futile
Ive used that trick a couple times and it works well.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
This works well when you already have a hole and want to hole saw it larger.
Happy to be here
![]() Join Date: Mar 2000
Great idea. On smaller holes, I have always used a wood rod as a filler. I guess it helps that I alwys have a surplus of broken pool sticks available.
