Old 02-21-2009, 02:14 PM   #1
S10Fan
Old Heap Driver
Quick Air ride Q
Quick question about compressor mounting. Eventually my compressor(s) and tank will be in the bed. For now, is it OK to mount a Viair 380C in most any position? Upside down etc. ?
Thanks!
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-21-2009, 07:35 PM   #2
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
Re: Quick Air ride Q
i dont think they suggest mounting it upside down but its ok if you mount it under the truck just make a bracket and you should be fine.
staggerd86c-10 is offline   Reply With Quote
Old 02-21-2009, 07:36 PM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Bagging the front of that heap, huh?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-21-2009, 07:41 PM   #4
S10Fan
Old Heap Driver
Thanks for the info.
Yes, the front is getting bagged this week. I'll get the rear done in a couple months, just not sure which way i want to go yet. I'm not looking to "lay frame", been wanting to bag something so here goes. LOL.
Bryan
Old 02-22-2009, 12:26 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
I suggest you mount that noisy SOB as far away from the cab as possible.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-22-2009, 02:15 AM   #6
Primer70
Superbad
Primer70's Avatar
This is what my buddy was told by Viair when he sent his compressors back on warranty. "Any position is fine, upright, sideways, upside down, but don't mount the compressor lower than the air tank. Mounting the compressor lower than the tank allows water to drain back into the pump, the water will cause the cylinder to corrode & shorten the life of the compressor." Sounds possible to me when I think about it. I will be mounting my compressors lower than my tanks, but I will be running water traps off my leader hoses lower than my pumps, then run line up to my tanks.
Primer70 is offline   Reply With Quote
Old 02-22-2009, 08:13 AM   #7
S10Fan
Old Heap Driver
LOL, I hear ya, barely. For now I’m going to use those big fat step side fenders to hide my compressors. I'm going to build a rain shield for them. As I posted earlier, the tank (34” X 7”, 5 gallon), and compressors will eventually move to the bed.
I see you’re using a “bag over spring” setup. You like it? That’s what I’m leaning towards on mine. If the axle will rest against the bottom of the C-notch (parked) I’ll be happy.
Bryan
Old 02-22-2009, 10:49 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by S10Fan View Post
.....I see you’re using a “bag over spring” setup. You like it? That’s what I’m leaning towards on mine. If the axle will rest against the bottom of the C-notch (parked) I’ll be happy.
I am very pleased with my AOL (air over leaf) system. I am pleased because it meet my very specific requirements. I wanted to go as low as possible, but would not cut the bed. I wanted a simple system that could be returned to stock if someone ever wanted to.
With the exception of a weld in C-notch I got all of my demands met with the AOL system....
Articles-
"Refining Sierra"
Old 02-23-2009, 05:59 AM   #9
S10Fan
Old Heap Driver
Thanks!
Bryan
Old 02-22-2009, 10:08 PM   #10
staggerd86c-10
what are you guys using to bag the front are you making the brackets yourself or buying them already made. I want to bag my truck too because im not happy with my ride height. What are you guys using for cnotches?
Old 02-22-2009, 10:53 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
On my 77 we used ART bag plates and cups with DJM 3" spindles. SOS custom built bump stops all me to still "roll" when aired out.
In the rear I have an SOS built C-notch that is welded in.
Articles-
"Refining Sierra"
Old 02-23-2009, 05:57 AM   #12
S10Fan
Old Heap Driver
I'm using a bolt in McGauleys (spelling?) C-Notch that I welded in. My bag brackets came from here....................
http://www.*****************/-63-87-f...-port-brackets
Bryan
Old 02-24-2009, 02:30 PM   #13
staggerd86c-10
what about the rear mounts is ART the only company that makes those air over leaf brackets?
